Hi if anyone has any advice at all that would be much appreciated, as I don’t really know what I am doing.
I have been following this guide as it describes how to set up the Marlin FW with the Hemera on the Ender 3, V2 with the silent board upgrade.
Hemera Creality Ender-3 V2 Firmware (Edition 2)
It’s my first time using the software but I have followed the guide exactly and believe I have set the project up correctly, but I am getting the issue below all ending with “there’s no such file or directory.”
I have also rebuilt the project from the scratch multiple times and each time it comes back with the same error.
I also did check the first directory listed in the error and it does exist on my computer, so not sure why it can’t see the folder when it goes to compile.
If anyone could help that would be incredible!
Cheers David
I have copied my terminal below just ignore the (REMOVED) where the HTTPS would be its just due to a limit on the number of links I can post sue to be a new user)
platformio run -e STM32F103RET6_creality ; echo "dbash: /Volumes/240GB | Home/.bash_profile: line 4: syntax error near unexpected token `|'
bash: /Volumes/240GB | Home/.bash_profile: line 4: `|'
Davids-iMac:Marlin-2.0.x user$ platformio run -e STM32F103RET6_creality ; echo "done" >|/var/folders/qw/hc6h8_n574bgtyj5m7f29t500000gn/T/ipc
Processing STM32F103RET6_creality (platform: ststm32@~12.1; board: genericSTM32F103RE; framework: arduino)
CONFIGURATION: (REMOVED)://docs.platformio.org/page/boards/ststm32/genericSTM32F103RE.html
PLATFORM: ST STM32 (12.1.1) > STM32F103RE (64k RAM. 512k Flash)
HARDWARE: STM32F103RET6 72MHz, 64KB RAM, 512KB Flash
DEBUG: Current (jlink) External (blackmagic, cmsis-dap, jlink, stlink)
- framework-arduinoststm32 4.10900.200819 (1.9.0)
- framework-cmsis 2.50501.200527 (5.5.1)
- toolchain-gccarmnoneeabi 1.90201.191206 (9.2.1)
Converting Marlin.ino
LDF: Library Dependency Finder -> (REMOVED)://bit.ly/configure-pio-ldf
Found 10 compatible libraries
|-- <SPI> 1.0
|-- <Servo> 1.1.2
|-- <EEPROM> 2.0.1
|-- <SoftwareSerial> 1.0
|-- <IWatchdog> 1.0.0
|-- <Wire> 1.0
Compiling .pio/build/STM32F103RET6_creality/FrameworkArduinoVariant/PeripheralPins.c.o
arm-none-eabi-gcc: error: Home/.platformio/packages/framework-arduinoststm32/cores/arduino/avr: No such file or directory
arm-none-eabi-gcc: error: Home/.platformio/packages/framework-arduinoststm32/cores/arduino/stm32: No such file or directory
arm-none-eabi-gcc: error: Home/.platformio/packages/framework-arduinoststm32/cores/arduino/stm32/LL: No such file or directory
arm-none-eabi-gcc: error: Home/.platformio/packages/framework-arduinoststm32/cores/arduino/stm32/usb: No such file or directory
arm-none-eabi-gcc: error: Home/.platformio/packages/framework-arduinoststm32/cores/arduino/stm32/OpenAMP: No such file or directory
arm-none-eabi-gcc: error: Home/.platformio/packages/framework-arduinoststm32/cores/arduino/stm32/usb/hid: No such file or directory
arm-none-eabi-gcc: error: Home/.platformio/packages/framework-arduinoststm32/cores/arduino/stm32/usb/cdc: No such file or directory
arm-none-eabi-gcc: error: Home/.platformio/packages/framework-arduinoststm32/system/Drivers/STM32F1xx_HAL_Driver/Inc: No such file or directory
arm-none-eabi-gcc: error: Home/.platformio/packages/framework-arduinoststm32/system/Drivers/STM32F1xx_HAL_Driver/Src: No such file or directory
arm-none-eabi-gcc: error: Home/.platformio/packages/framework-arduinoststm32/system/STM32F1xx: No such file or directory
arm-none-eabi-gcc: error: Home/.platformio/packages/framework-arduinoststm32/system/Middlewares/ST/STM32_USB_Device_Library/Core/Inc: No such file or directory
arm-none-eabi-gcc: error: Home/.platformio/packages/framework-arduinoststm32/system/Middlewares/ST/STM32_USB_Device_Library/Core/Src: No such file or directory
arm-none-eabi-gcc: error: Home/.platformio/packages/framework-arduinoststm32/system/Middlewares/OpenAMP: No such file or directory
arm-none-eabi-gcc: error: Home/.platformio/packages/framework-arduinoststm32/system/Middlewares/OpenAMP/open-amp/lib/include: No such file or directory
arm-none-eabi-gcc: error: Home/.platformio/packages/framework-arduinoststm32/system/Middlewares/OpenAMP/libmetal/lib/include: No such file or directory
arm-none-eabi-gcc: error: Home/.platformio/packages/framework-arduinoststm32/system/Middlewares/OpenAMP/virtual_driver: No such file or directory
arm-none-eabi-gcc: error: Home/.platformio/packages/framework-cmsis/CMSIS/Core/Include: No such file or directory
arm-none-eabi-gcc: error: Home/.platformio/packages/framework-arduinoststm32/system/Drivers/CMSIS/Device/ST/STM32F1xx/Include: No such file or directory
arm-none-eabi-gcc: error: Home/.platformio/packages/framework-arduinoststm32/system/Drivers/CMSIS/Device/ST/STM32F1xx/Source/Templates/gcc: No such file or directory
arm-none-eabi-gcc: error: Home/.platformio/packages/framework-cmsis/CMSIS/DSP/Include: No such file or directory
arm-none-eabi-gcc: error: Home/.platformio/packages/framework-arduinoststm32/cores/arduino: No such file or directory
arm-none-eabi-gcc: error: Home/.platformio/packages/framework-arduinoststm32/variants/MARLIN_F103Rx: No such file or directory
Compiling .pio/build/STM32F103RET6_creality/FrameworkArduinoVariant/variant.cpp.o
arm-none-eabi-g++: error: Home/.platformio/packages/framework-arduinoststm32/cores/arduino/avr: No such file or directory
arm-none-eabi-g++: error: Home/.platformio/packages/framework-arduinoststm32/cores/arduino/stm32: No such file or directory
arm-none-eabi-g++: error: Home/.platformio/packages/framework-arduinoststm32/cores/arduino/stm32/LL: No such file or directory
arm-none-eabi-g++: error: Home/.platformio/packages/framework-arduinoststm32/cores/arduino/stm32/usb: No such file or directory
arm-none-eabi-g++: error: Home/.platformio/packages/framework-arduinoststm32/cores/arduino/stm32/OpenAMP: No such file or directory
arm-none-eabi-g++: error: Home/.platformio/packages/framework-arduinoststm32/cores/arduino/stm32/usb/hid: No such file or directory
arm-none-eabi-g++: error: Home/.platformio/packages/framework-arduinoststm32/cores/arduino/stm32/usb/cdc: No such file or directory
arm-none-eabi-g++: error: Home/.platformio/packages/framework-arduinoststm32/system/Drivers/STM32F1xx_HAL_Driver/Inc: No such file or directory
arm-none-eabi-g++: error: Home/.platformio/packages/framework-arduinoststm32/system/Drivers/STM32F1xx_HAL_Driver/Src: No such file or directory
arm-none-eabi-g++: error: Home/.platformio/packages/framework-arduinoststm32/system/STM32F1xx: No such file or directory
arm-none-eabi-g++: error: Home/.platformio/packages/framework-arduinoststm32/system/Middlewares/ST/STM32_USB_Device_Library/Core/Inc: No such file or directory
arm-none-eabi-g++: error: Home/.platformio/packages/framework-arduinoststm32/system/Middlewares/ST/STM32_USB_Device_Library/Core/Src: No such file or directory
arm-none-eabi-g++: error: Home/.platformio/packages/framework-arduinoststm32/system/Middlewares/OpenAMP: No such file or directory
arm-none-eabi-g++: error: Home/.platformio/packages/framework-arduinoststm32/system/Middlewares/OpenAMP/open-amp/lib/include: No such file or directory
arm-none-eabi-g++: error: Home/.platformio/packages/framework-arduinoststm32/system/Middlewares/OpenAMP/libmetal/lib/include: No such file or directory
arm-none-eabi-g++: error: Home/.platformio/packages/framework-arduinoststm32/system/Middlewares/OpenAMP/virtual_driver: No such file or directory
arm-none-eabi-g++: error: Home/.platformio/packages/framework-cmsis/CMSIS/Core/Include: No such file or directory
arm-none-eabi-g++: error: Home/.platformio/packages/framework-arduinoststm32/system/Drivers/CMSIS/Device/ST/STM32F1xx/Include: No such file or directory
arm-none-eabi-g++: error: Home/.platformio/packages/framework-arduinoststm32/system/Drivers/CMSIS/Device/ST/STM32F1xx/Source/Templates/gcc: No such file or directory
arm-none-eabi-g++: error: Home/.platformio/packages/framework-cmsis/CMSIS/DSP/Include: No such file or directory
arm-none-eabi-g++: error: Home/.platformio/packages/framework-arduinoststm32/cores/arduino: No such file or directory
arm-none-eabi-g++: error: Home/.platformio/packages/framework-arduinoststm32/variants/MARLIN_F103Rx: No such file or directory
Compiling .pio/build/STM32F103RET6_creality/FrameworkArduino/HardwareSerial.cpp.o
Compiling .pio/build/STM32F103RET6_creality/FrameworkArduino/HardwareTimer.cpp.o
Compiling .pio/build/STM32F103RET6_creality/FrameworkArduino/IPAddress.cpp.o
*** [.pio/build/STM32F103RET6_creality/FrameworkArduinoVariant/PeripheralPins.c.o] Error 1
Compiling .pio/build/STM32F103RET6_creality/FrameworkArduino/Print.cpp.o
*** [.pio/build/STM32F103RET6_creality/FrameworkArduinoVariant/variant.cpp.o] Error 1
*** [.pio/build/STM32F103RET6_creality/FrameworkArduino/HardwareSerial.cpp.o] Error 1
*** [.pio/build/STM32F103RET6_creality/FrameworkArduino/HardwareTimer.cpp.o] Error 1
*** [.pio/build/STM32F103RET6_creality/FrameworkArduino/IPAddress.cpp.o] Error 1
*** [.pio/build/STM32F103RET6_creality/FrameworkArduino/Print.cpp.o] Error 1
================================================= [FAILED] Took 2.23 seconds =================================================
Environment Status Duration
STM32F103RET6_creality FAILED 00:00:02.230
=========================================== 1 failed, 0 succeeded in 00:00:02.230 ===========================================
