PlatformIO Community
Marlin 2.0 Build Issues with Plaformio Mac
I am trying to build Marlin Bugfix 2.0.x Everytime I build I am getting the following errors wheather I use Platformio through Atom or Vscode on my mac.
I can borrow a friends windows laptop and the same files build perfectly.
Is there something incorrect with the python instal on my system?
Processing LPC1768 (platform: https://github.com/p3p/pio-nxplpc-arduino-lpc176x/archive/maste
r.zip; framework: arduino; board: nxp_lpc1768)
PackageManager: Installing toolchain-gccarmnoneeabi @ >=1.80201.181221
Downloading...
Unpacking...
toolchain-gccarmnoneeabi @ 1.80201.181221 has been successfully installed!
CONFIGURATION: https://docs.platformio.org/page/boards/nxplpc-arduino-lpc176x/nxp_lpc1768.htm
l
PLATFORM: NXP Arduino LPC176x 0.0.2 > NXP LPC1768
HARDWARE: LPC1768 100MHz, 31.80KB RAM, 464KB Flash
DEBUG: Current (cmsis-dap) On-board (cmsis-dap) External (blackmagic, jlink)
PACKAGES: framework-arduino-lpc176x 0.1.3
Converting Marlin.ino
sh: arm-none-eabi-g++: command not found
*** Error 127
AssertionError: :
  File "/Volumes/Macintosh HDD/samuelread/.platformio/penv/lib/python2.7/site-packages/platfo
rmio/builder/main.py", line 126:
  File "/Volumes/Macintosh HDD/samuelread/.platformio/packages/tool-scons/script/../engine/SC
ons/Script/SConscript.py", line 541:
ons/Script/SConscript.py", line 250:
    exec _file_ in call_stack[-1].globals
  File "/Volumes/Macintosh HDD/samuelread/.platformio/platforms/nxplpc-arduino-lpc176x/builde
r/main.py", line 136:
ons/Environment.py", line 224:
rmio/builder/tools/platformio.py", line 110:
rmio/builder/tools/platformio.py", line 288:
    env.ConvertInoToCpp()
rmio/builder/tools/piomisc.py", line 198:
out_file = c.convert(ino_nodes)
rmio/builder/tools/piomisc.py", line 57:
    return self.process(contents)
rmio/builder/tools/piomisc.py", line 80:
    assert self._gcc_preprocess(contents, out_file)
========================= [FAILED] Took 154.12 seconds =========================
Thanks,
This exact same error was discussed in this thread already: Can not compile: arm-none-eabi-g++: command not found
The people you download the Marlin firmware from only supply an extra linux compiler (and the current windows one works too), but not a Mac-OS one. You will have to do some hacking.
Ah Thank you for the link. I tried to search for related subjects but didn’t find this one. I am still having an issue but I will post in the linked thread if I cannot sort it myself.
Thank you
