I am testing a code captured by pwm. The original code belongs to the core of Maple.
Because I only have a Nucleo F446RE board and my network cannot update the Maple core, I tried to port the code to the STM32 core.
This is original code for Malpe core
int32_t channel_1_start, channel_1_stop, channel_1;
Serial.begin(57600);
pinMode(PA0, INPUT);
delay(250);
Timer2.attachCompare1Interrupt(handler_channel_1);
TIMER2_BASE->CR1 = TIMER_CR1_CEN;
TIMER2_BASE->CR2 = 0;
TIMER2_BASE->SMCR = 0;
TIMER2_BASE->DIER = TIMER_DIER_CC1IE;
TIMER2_BASE->EGR = 0;
TIMER2_BASE->CCMR1 = TIMER_CCMR1_CC1S_INPUT_TI1;
TIMER2_BASE->CCMR2 = 0;
TIMER2_BASE->CCER = TIMER_CCER_CC1E;
TIMER2_BASE->PSC = 71;
TIMER2_BASE->ARR = 0xFFFF;
TIMER2_BASE->DCR = 0;
delay(1000);
Serial.println(channel_1);
void handler_channel_1(void) {
if (0b1 & GPIOA_BASE->IDR) {
channel_1_start = TIMER2_BASE->CCR1;
TIMER2_BASE->CCER |= TIMER_CCER_CC1P;
else {
channel_1 = TIMER2_BASE->CCR1 - channel_1_start;
if (channel_1 < 0)channel_1 += 0xFFFF;
TIMER2_BASE->CCER &= ~TIMER_CCER_CC1P;
This is the code I modified for the stm32 core
if (0b1 & GPIOA->IDR) {
channel_1_start = TIM2->CCR1;
TIM2->CCER |= TIM_CCER_CC1P;
else {
channel_1 = TIM2->CCR1 - channel_1_start;
TIM2->CCER &= ~TIM_CCER_CC1P;
delay(250);
TIM2->CR1 = TIM_CR1_CEN;
TIM2->CR2 = 0;
TIM2->SMCR = 0;
TIM2->DIER = TIM_DIER_CC1IE;
TIM2->EGR = 0;
TIM2->CCMR1 = TIM_CCMR1_IC1PSC;
TIM2->CCMR2 = 0;
TIM2->CCER = TIM_CCER_CC1E;
TIM2->PSC = 71;
TIM2->ARR = 0xFFFF;
TIM2->DCR = 0;
delay(1000);
I’m not sure if my modification like this is feasible, because there was a compilation warning, I have never been able to compile successfully.
Processing nucleo_f446re (platform: ststm32; board: nucleo_f446re; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/nucleo_f446re.html
PLATFORM: ST STM32 (12.0.0) > ST Nucleo F446RE
HARDWARE: STM32F446RET6 180MHz, 128KB RAM, 512KB Flash
- framework-arduinoststm32 4.10900.200819 (1.9.0)
- framework-cmsis 2.50501.200527 (5.5.1)
- toolchain-gccarmnoneeabi 1.90201.191206 (9.2.1)
Found 18 compatible libraries
Compiling .pio/build/nucleo_f446re/src/main.cpp.o
src/main.cpp: In function 'void setup()':
src/main.cpp:21:3: error: 'Timer2' was not declared in this scope
21 | Timer2.attachCompare1Interrupt(handler_channel_1);
*** [.pio/build/nucleo_f446re/src/main.cpp.o] Error 1
