Sure, here is the full log:
Processing sipeed-maix-go (platform: kendryte210; framework: arduino; board: sipeed-maix-go)
CONFIGURATION: https://docs.platformio.org/page/boards/kendryte210/sipeed-maix-go.html
PLATFORM: Kendryte K210 1.1.1 > Sipeed MAIX GO
HARDWARE: K210 400MHz, 6MB RAM, 16MB Flash
DEBUG: Current (iot-bus-jtag) External (iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, sipeed-rv-debugger, tumpa)
PACKAGES: tool-kflash-kendryte210 0.9.1, tool-openocd-kendryte 1.203.1 (2.3), toolchain-kendryte210 8.2.0, framework-maixduino 0.3.9
Found 14 compatible libraries
Checking size .pio/build/sipeed-maix-go/firmware.elf
DATA: [ ] 0.5% (used 32456 bytes from 6291456 bytes)
PROGRAM: [ ] 0.4% (used 68247 bytes from 16777216 bytes)
AVAILABLE: iot-bus-jtag, jlink, kflash, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, sipeed-rv-debugger, tumpa
CURRENT: upload_protocol = kflash
Looking for upload port...
Auto-detected: /dev/ttyUSB0
Uploading .pio/build/sipeed-maix-go/firmware.bin
[INFO] COM Port Auto Detected, Selected /dev/ttyUSB1
[INFO] Default baudrate is 115200 , later it may be changed to the value you set.
[INFO] Trying to Enter the ISP Mode...
Greeting fail, check serial port ([ERROR] No vaild Kendryte K210 found in Auto Detect, Check Your Connection or Specify One by`-p /dev/ttyUSB0` )
*** [upload] Error 1
========================= [FAILED] Took 13.85 seconds =========================
Processing sipeed-maix-one-dock (platform: kendryte210; framework: arduino; board: sipeed-maix-one-dock)
CONFIGURATION: https://docs.platformio.org/page/boards/kendryte210/sipeed-maix-one-dock.html
PLATFORM: Kendryte K210 1.1.1 > Sipeed MAIX ONE DOCK
Checking size .pio/build/sipeed-maix-one-dock/firmware.elf
Uploading .pio/build/sipeed-maix-one-dock/firmware.bin
[INFO] COM Port Selected Manually: /dev/ttyUSB0
========================= [FAILED] Took 13.83 seconds =========================
Processing sipeed-maix-bit (platform: kendryte210; framework: arduino; board: sipeed-maix-bit)
CONFIGURATION: https://docs.platformio.org/page/boards/kendryte210/sipeed-maix-bit.html
PLATFORM: Kendryte K210 1.1.1 > Sipeed MAIX BiT
Checking size .pio/build/sipeed-maix-bit/firmware.elf
Uploading .pio/build/sipeed-maix-bit/firmware.bin
========================= [FAILED] Took 13.77 seconds =========================
Processing sipeed-maixduino (platform: kendryte210; framework: arduino; board: sipeed-maixduino)
CONFIGURATION: https://docs.platformio.org/page/boards/kendryte210/sipeed-maixduino.html
PLATFORM: Kendryte K210 1.1.1 > Sipeed MAIXDUINO
Checking size .pio/build/sipeed-maixduino/firmware.elf
DATA: [ ] 0.5% (used 32424 bytes from 6291456 bytes)
PROGRAM: [ ] 0.4% (used 68255 bytes from 16777216 bytes)
Uploading .pio/build/sipeed-maixduino/firmware.bin
[INFO] Greeting Message Detected, Start Downloading ISP
[INFO] Selected Stage0 Baudrate: 1500000
[INFO] FT2232 mode
Downloading ISP: |=============================================| 100.0% 61kiB/s
[INFO] Booting From 0x80000000
[INFO] Wait For 0.1 second for ISP to Boot
[INFO] Boot to Flashmode Successfully
[INFO] Selected Baudrate: 1500000
[INFO] Baudrate changed, greeting with ISP again ...
[INFO] Selected Flash: On-Board
[INFO] Initialization flash Successfully
Programming BIN: |=============================================| 100.0% 55kiB/s
[INFO] Rebooting...
========================= [SUCCESS] Took 5.83 seconds =========================
Environment Status Duration
sipeed-maix-go FAILED 00:00:13.848
sipeed-maix-one-dock FAILED 00:00:13.830
sipeed-maix-bit FAILED 00:00:13.775
sipeed-maixduino SUCCESS 00:00:05.830
==================== 3 failed, 1 succeeded in 00:00:47.282 ====================
Is it? I assume that the Maix Bit and Maixduino have slightly different hardware, so if I use sipeed-maixduino
to develop for my Maix Bit, presumably I’ll run into failures on some peripherals? Even on the blink example, it is not blinking the LED on my board. (Presumably because the Maix Bit has the built-in LED on a different pin than the Maixduino.)
