i can’t upload to my nodemcuv2 board even though the usb device is there:
misws-iMac:testapp02 misw$ pio device list
/dev/cu.wchusbserial14340
Hardware ID: USB VID:PID=1A86:7523 LOCATION=20-3.4
Description: USB2.0-Serial
even the serial monitor works.
the platformio.ini is:
[env:nodemcuv2]
platform = espressif8266
board = nodemcuv2
upload_port = /dev/cu.wchusbserial14320
when i do an upload, the usb device is not available:
instance.open()
File “/Users/misw/.platformio/penv/lib/python2.7/site-packages/serial/serialposix.py”, line 268, in open
raise SerialException(msg.errno, “could not open port {}: {}”.format(self._port, msg))
serial.serialutil.SerialException: [Errno 2] could not open port /dev/cu.wchusbserial14320: [Errno 2] No>such file or directory: ‘/dev/cu.wchusbserial14320’
The port works for the Arduino IDE.
Any suggestions?
Thanks
moik
Addon:
i can upload via this port to an arduino nano with platformio (same chip), so it seems the it is an issue with the nodemcu.
it seems that there is a pio bug:
when i’m creating a sym link from /dev/cu.wchusbserial14320 to /dev/usb01, everything works!
the problem seems to be the dot in cu.wchusbserial14320.
do only i hav ethis issue? i’m on macos mojave.
Can you check what version of the platformio espressif8266 platform package you’re using - you can run pio update -c to run a check only. If it’s not version 2.2.2, can you run pio update so that it gets updated, and try again?
Hi pfeerick,
it’s
> Platform Espressif 8266
> Checking espressif8266 @ 2.2.2 [Up-to-date]
> Checking tool-esptoolpy @ 1.20600.0 [Up-to-date]
> Checking tool-mkspiffs @ 1.200.0 [Up-to-date]
> Checking tool-esptool @ 1.413.0 [Up-to-date]
> Checking framework-arduinoespressif8266 @ 2.20502.0 [Up-to-date]
> Checking toolchain-xtensa @ 2.40802.190218 [Up-to-date]
so everything seems to be ok.
Yes, that’s all good. Thanks
Just double check that path… the pio device list output ends 40, but you’ve got 20 in your platformio.ini…
Ehm, that’s embarrassing
Will change my nickname.
Thanks pfeerick!
(but i still wonder where that 20 came from, it was all c&p
lol… no need… I’d be changing mine every second day if that was the case!
Just glad we figured it out… I was thinking that major / annoying a bug couldn’t have been in the pyserial library all this time and not found!
