Mac M3 can't build
Hello, I’m new around here so I wan’t to apologize if I selected the wrong topic.
Yesterday I bought a Mac with an M3 chip, and when I tried building a fresh pio project I got some errors that I’ve never seen before.
I’m guessing it has to do with the M3 chip due to the “Bad cpu type in executable” message…
Someone encountered this before and can help me fix it?
Processing d1_mini (platform: espressif8266; board: d1_mini; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/d1_mini.html
PLATFORM: Espressif 8266 (4.2.1) > WeMos D1 R2 and mini
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
 - framework-arduinoespressif8266 @ 3.30102.0 (3.1.2)
 - tool-esptool @ 1.413.0 (4.13)
 - tool-esptoolpy @ 1.30000.201119 (3.0.0)
 - toolchain-xtensa @ 2.100300.220621 (10.3.0)
Found 37 compatible libraries
Compiling .pio/build/d1_mini/src/main.cpp.o
sh: /Users/martin/.platformio/packages/toolchain-xtensa/bin/xtensa-lx106-elf-g++: Bad CPU type in executable
Generating LD script .pio/build/d1_mini/ld/local.eagle.app.v6.common.ld
Archiving .pio/build/d1_mini/libFrameworkArduinoVariant.a
sh: /Users/martin/.platformio/packages/toolchain-xtensa/bin/xtensa-lx106-elf-gcc: Bad CPU type in executable
sh: /Users/martin/.platformio/packages/toolchain-xtensa/bin/xtensa-lx106-elf-ar: Bad CPU type in executable
Compiling .pio/build/d1_mini/FrameworkArduino/Crypto.cpp.o
Compiling .pio/build/d1_mini/FrameworkArduino/Esp-frag.cpp.o
Compiling .pio/build/d1_mini/FrameworkArduino/Esp-version.cpp.o
Compiling .pio/build/d1_mini/FrameworkArduino/Esp.cpp.o
Compiling .pio/build/d1_mini/FrameworkArduino/FS.cpp.o
Compiling .pio/build/d1_mini/FrameworkArduino/FSnoop.cpp.o
Compiling .pio/build/d1_mini/FrameworkArduino/FunctionalInterrupt.cpp.o
*** [.pio/build/d1_mini/src/main.cpp.o] Error 126
*** [.pio/build/d1_mini/ld/local.eagle.app.v6.common.ld] Error 126
*** [.pio/build/d1_mini/libFrameworkArduinoVariant.a] Error 126
*** [.pio/build/d1_mini/FrameworkArduino/Crypto.cpp.o] Error 126
*** [.pio/build/d1_mini/FrameworkArduino/Esp-frag.cpp.o] Error 126
*** [.pio/build/d1_mini/FrameworkArduino/Esp-version.cpp.o] Error 126
*** [.pio/build/d1_mini/FrameworkArduino/Esp.cpp.o] Error 126
*** [.pio/build/d1_mini/FrameworkArduino/FS.cpp.o] Error 126
*** [.pio/build/d1_mini/FrameworkArduino/FSnoop.cpp.o] Error 126
Compiling .pio/build/d1_mini/FrameworkArduino/HardwareSerial.cpp.o
*** [.pio/build/d1_mini/FrameworkArduino/FunctionalInterrupt.cpp.o] Error 126
*** [.pio/build/d1_mini/FrameworkArduino/HardwareSerial.cpp.o] Error 126
Did you install Rosetta to get x64 emulation? All the “Mac ARM” packages are x64 binaries and rely on that emulation, barely any binary is native ARM.
That fix it!! Thank you, first time on ARM :sweat_smile:
To install rosetta I installed steam (which is in the list of apps that do require rosetta to work) and when running steam, it asked me to install rosetta. So it was very easy to do if it can help you!
Thank you random stranger on the internet!
