I am trying to run LVGL Demo (GitHub - lvgl/lv_platformio: PlatformIO project example for LVGL) on an ESP8266 and ili9341 display
I can run a custom code with Adafruit lib and I can run the LVGL on the simulator.
My platformio.ini is below
When I try to run the LVGL Demo on the board I get this error:
Linking .pio/build/env1/firmware.elf
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/firmware.elf section `.rodata' will not fit in region `dram0_0_seg'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: address 0x4000b4e8 of .pio/build/env1/firmware.elf section `.bss' is not within region `dram0_0_seg'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o:(.text.tick_thread+0x0): undefined reference to `SDL_Delay'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o: in function `tick_thread':
sdl.c:(.text.tick_thread+0x12): undefined reference to `SDL_Delay'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o:(.text.window_update$constprop$0+0x4): undefined reference to `SDL_UpdateTexture'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o:(.text.window_update$constprop$0+0x8): undefined reference to `SDL_RenderClear'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o:(.text.window_update$constprop$0+0xc): undefined reference to `SDL_RenderCopy'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o:(.text.window_update$constprop$0+0x10): undefined reference to `SDL_RenderPresent'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o: in function `window_update$constprop$0':
sdl.c:(.text.window_update$constprop$0+0x28): undefined reference to `SDL_UpdateTexture'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: sdl.c:(.text.window_update$constprop$0+0x30): undefined reference to `SDL_RenderClear'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: sdl.c:(.text.window_update$constprop$0+0x3e): undefined reference to `SDL_RenderCopy'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o:(.text.sdl_event_handler+0x30): undefined reference to `SDL_PollEvent'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o:(.text.sdl_event_handler+0x34): undefined reference to `SDL_DestroyTexture'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o:(.text.sdl_event_handler+0x38): undefined reference to `SDL_DestroyRenderer'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o:(.text.sdl_event_handler+0x3c): undefined reference to `SDL_DestroyWindow'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o:(.text.sdl_event_handler+0x40): undefined reference to `SDL_Quit'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o: in function `sdl_event_handler':
sdl.c:(.text.sdl_event_handler+0x288): undefined reference to `SDL_PollEvent'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: sdl.c:(.text.sdl_event_handler+0x2a3): undefined reference to `SDL_DestroyTexture'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: sdl.c:(.text.sdl_event_handler+0x2ab): undefined reference to `SDL_DestroyRenderer'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: sdl.c:(.text.sdl_event_handler+0x2b3): undefined reference to `SDL_DestroyWindow'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: sdl.c:(.text.sdl_event_handler+0x2b9): undefined reference to `SDL_Quit'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o:(.text.sdl_init+0x1c): undefined reference to `SDL_Init'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o:(.text.sdl_init+0x20): undefined reference to `SDL_SetEventFilter'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o:(.text.sdl_init+0x24): undefined reference to `SDL_CreateWindow'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o:(.text.sdl_init+0x28): undefined reference to `SDL_CreateRenderer'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o:(.text.sdl_init+0x2c): undefined reference to `SDL_CreateTexture'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o:(.text.sdl_init+0x30): undefined reference to `SDL_SetTextureBlendMode'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o:(.text.sdl_init+0x34): undefined reference to `SDL_StartTextInput'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o:(.text.sdl_init+0x38): undefined reference to `SDL_CreateThread'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o:(.text.sdl_init+0x4b): undefined reference to `SDL_Init'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/lib04c/lv_drivers/sdl/sdl.c.o: in function `sdl_init':
sdl.c:(.text.sdl_init+0x57): undefined reference to `SDL_SetEventFilter'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: sdl.c:(.text.sdl_init+0x6f): undefined reference to `SDL_CreateWindow'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: sdl.c:(.text.sdl_init+0x7f): undefined reference to `SDL_CreateRenderer'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: sdl.c:(.text.sdl_init+0x93): undefined reference to `SDL_CreateTexture'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: sdl.c:(.text.sdl_init+0xa4): undefined reference to `SDL_SetTextureBlendMode'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: sdl.c:(.text.sdl_init+0xc6): undefined reference to `SDL_StartTextInput'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: sdl.c:(.text.sdl_init+0xd4): undefined reference to `SDL_CreateThread'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/hal/sdl2/app_hal.c.o: in function `tick_thread':
app_hal.c:(.text.tick_thread+0xe): undefined reference to `SDL_Delay'
/Users/eduardo/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: .pio/build/env1/hal/sdl2/app_hal.c.o:(.text.hal_loop+0x7): undefined reference to `SDL_Delay'
*** [.pio/build/env1/firmware.elf] Error 1
The Platformio.ini looks like
[platformio]
default_envs = env1
[env]
-D LV_CONF_SKIP
-D LV_CONF_INCLUDE_SIMPLE
-D LV_USE_DEMO_WIDGETS=1
lib_deps = lvgl=https://github.com/lvgl/lvgl/archive/refs/tags/v8.2.0.zip
lib_archive = no
[env:emulator_64bits]
platform = native@^1.1.3
extra_scripts = support/sdl2_build_extra.py
${env.build_flags}
-D LV_LOG_PRINTF=1
!python -c "import os; print(' '.join(['-I {}'.format(i[0].replace('\x5C','/')) for i in os.walk('hal/sdl2')]))"
-lSDL2
-D LV_LVGL_H_INCLUDE_SIMPLE
-D LV_DRV_NO_CONF
-D USE_SDL
-D SDL_HOR_RES=480
-D SDL_VER_RES=320
-D SDL_ZOOM=1
-D SDL_INCLUDE_PATH="\"SDL2/SDL.h\""
-D LV_MEM_CUSTOM=1
-D LV_MEM_SIZE="(128U * 1024U)"
-I /opt/homebrew/Cellar/sdl2/2.26.3/include
-L /opt/homebrew/Cellar/sdl2/2.26.3/lib
${env.lib_deps}
lv_drivers=https://github.com/lvgl/lv_drivers/archive/refs/tags/v8.2.0.zip
build_src_filter =
+<../hal/sdl2>
+<../.pio/libdeps/emulator_64bits/lvgl/demos>
[env:emulator_32bits]
extends = env:emulator_64bits
${env:emulator_64bits.build_flags}
-m32
build_src_filter =
+<../hal/sdl2>
+<../.pio/libdeps/emulator_32bits/lvgl/demos>
[env:stm32f429_disco]
platform = ststm32@^8.0.0
board = disco_f429zi
framework = stm32cube
${env.build_flags}
-D LV_LOG_LEVEL=LV_LOG_LEVEL_NONE
-D HSE_VALUE=8000000
!python -c "import os; print(' '.join(['-I {}'.format(i[0].replace('\x5C','/')) for i in os.walk('hal/stm32f429_disco')]))"
${env.lib_deps}
BSP-ili9341
BSP-stmpe811
build_src_filter =
+<../hal/stm32f429_disco>
+<../.pio/libdeps/stm32f429_disco/lvgl/demos>
[env:env1]
platform = espressif8266
board = nodemcuv2
${env.build_flags}
-D LV_LOG_PRINTF=1
-lSDL2
-D LV_DRV_NO_CONF
-D USE_SDL
-D SDL_HOR_RES=480
-D SDL_VER_RES=320
-D SDL_ZOOM=1
-D LV_MEM_CUSTOM=1
${env.lib_deps}
SPI
build_src_filter =
+<../hal/sdl2>
Listing the folder “/opt/homebrew/Cellar/sdl2/2.26.3/include/SDL2” I don’t see the “SDL_Delay”
