Any assistance would be greatly appreciated,
Getting the error output here:
‘sprintf’ may write a terminating nul past the end of the destination [-Wformat-overflow=]
Here are the build Messages:
> Executing task: C:\Users\stephen\.platformio\penv\Scripts\platformio.exe run <
Processing LPC1769 (platform: ://github.com/p3p/pio-nxplpc-arduino-lpc176x/archive/0.1.3.zip; board: nxp_lpc1769; framework: arduino)
CONFIGURATION:://docs.platformio.org/page/boards/nxplpc-arduino-lpc176x/nxp_lpc1769.html
PLATFORM: NXP Arduino LPC176x (0.1.3) > NXP LPC1769
HARDWARE: LPC1769 120MHz, 31.97KB RAM, 464KB Flash
DEBUG: Current (cmsis-dap) On-board (cmsis-dap) External (blackmagic, jlink)
- framework-arduino-lpc176x 0.2.9
- toolchain-gccarmnoneeabi 1.100301.220327 (10.3.1)
Converting Marlin.ino
LDF: Library Dependency Finder ->s://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ off, Compatibility ~ strict
Found 3 compatible libraries
|-- <Servo> 1.0.0
|-- <TMCStepper> 0.7.3
|-- <U8glib-HAL> 0.4.1
upload disk: I:
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\DebugMonitor.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\HAL.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\HAL_SPI.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\MarlinSerial.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\eeprom_flash.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\eeprom_sdcard.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\eeprom_wired.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\fast_pwm.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\include\digipot_mcp4451_I2C_routines.c.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\include\i2c_util.c.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\main.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\tft\tft_spi.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\tft\xpt2046.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\timers.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\u8g\LCD_I2C_routines.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\u8g\LCD_pin_routines.c.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\u8g\u8g_com_HAL_LPC1768_hw_spi.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\u8g\u8g_com_HAL_LPC1768_ssd_hw_i2c.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\u8g\u8g_com_HAL_LPC1768_st7920_hw_spi.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\u8g\u8g_com_HAL_LPC1768_st7920_sw_spi.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\u8g\u8g_com_HAL_LPC1768_sw_spi.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\usb_serial.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\watchdog.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\shared\HAL_spi_L6470.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\shared\backtrace\backtrace.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\shared\backtrace\unwarm.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\shared\backtrace\unwarm_arm.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\shared\backtrace\unwarm_thumb.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\shared\backtrace\unwarmbytab.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\shared\backtrace\unwarmmem.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\shared\backtrace\unwinder.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\shared\backtrace\unwmemaccess.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\shared\eeprom_api.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\shared\eeprom_if_i2c.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\shared\eeprom_if_spi.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\shared\esp_wifi.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\shared\servo.cpp.o
Compiling .pio\build\LPC1769\src\src\MarlinCore.cpp.o
Compiling .pio\build\LPC1769\src\src\core\serial.cpp.o
Compiling .pio\build\LPC1769\src\src\core\utility.cpp.o
Compiling .pio\build\LPC1769\src\src\feature\babystep.cpp.o
Compiling .pio\build\LPC1769\src\src\feature\bedlevel\bedlevel.cpp.o
Compiling .pio\build\LPC1769\src\src\feature\bedlevel\ubl\ubl.cpp.o
Compiling .pio\build\LPC1769\src\src\feature\bedlevel\ubl\ubl_G29.cpp.o
Compiling .pio\build\LPC1769\src\src\feature\bedlevel\ubl\ubl_motion.cpp.o
Compiling .pio\build\LPC1769\src\src\feature\caselight.cpp.o
Compiling .pio\build\LPC1769\src\src\feature\leds\neopixel.cpp.o
Compiling .pio\build\LPC1769\src\src\feature\tmc_util.cpp.o
Compiling .pio\build\LPC1769\src\src\feature\z_stepper_align.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\bedlevel\G42.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\bedlevel\M420.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\bedlevel\ubl\G29.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\bedlevel\ubl\M421.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\calibrate\G28.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\calibrate\G34_M422.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\calibrate\M48.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\config\M200-M205.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\config\M220.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\config\M221.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\config\M301.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\config\M302.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\config\M304.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\config\M575.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\config\M672.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\config\M92.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\control\M108_M112_M410.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\control\M111.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\control\M120_M121.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\control\M17_M18_M84.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\control\M211.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\control\M226.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\control\M280.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\control\M350_M351.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\control\M380_M381.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\control\M400.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\control\M42.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\control\M80_M81.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\control\M85.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\control\M993_M994.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\control\M997.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\control\M999.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\control\T.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\eeprom\M500-M504.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\feature\digipot\M907-M910.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\feature\trinamic\M122.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\feature\trinamic\M569.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\feature\trinamic\M906.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\feature\trinamic\M911-M914.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\gcode.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\geometry\G92.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\geometry\M206_M428.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\host\M110.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\host\M113.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\host\M114.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\host\M115.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\host\M118.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\host\M119.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\lcd\M0_M1.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\lcd\M117.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\lcd\M145.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\lcd\M300.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\motion\G0_G1.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\motion\G2_G3.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\motion\G4.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\motion\M290.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\parser.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\probe\G30.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\probe\M401_M402.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\probe\M851.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\queue.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M1001.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M20.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M21_M22.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M23.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M24_M25.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M26.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M27.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M28_M29.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M30.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M32.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M33.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M34.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M524.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M928.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\stats\M31.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\stats\M75-M78.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\temp\M104_M109.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\temp\M105.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\temp\M106_M107.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\temp\M140_M190.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\temp\M141_M191.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\temp\M155.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\temp\M303.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\units\M82_M83.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\dogm\lcdprint_u8g.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\dogm\status_screen_DOGM.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\dogm\status_screen_lite_ST7920.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\dogm\u8g_dev_ssd1306_sh1106_128x64_I2C.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\dogm\u8g_dev_st7565_64128n_HAL.cpp.o
In file included from Marlin\src\gcode\stats\../../inc/../HAL/./LPC1768/../shared/Marduino.h:36,
from Marlin\src\gcode\stats\../../inc/../HAL/./LPC1768/HAL.h:39,
from Marlin\src\gcode\stats\../../inc/../HAL/HAL.h:26,
from Marlin\src\gcode\stats\../../inc/MarlinConfig.h:30,
from Marlin\src\gcode\stats\../gcode.h:294,
from Marlin\src\gcode\stats\M31.cpp:23:
Marlin\src\gcode\stats\../../module/../libs/duration_t.h: In static member function 'static void GcodeSuite::M31()':
Marlin\src\gcode\stats\../../module/../libs/duration_t.h:130:35: warning: 'sprintf' may write a terminating nul past the end of the destination [-Wformat-overflow=]
130 | if (y) sprintf_P(buffer, PSTR("%iy %id %ih %im %is"), y, d, h, m, s);
C:\Users\stephen\.platformio\packages\framework-arduino-lpc176x\cores\arduino/Arduino.h:58:18: note: in definition of macro 'PSTR'
58 | #define PSTR(v) (v)
In file included from Marlin\src\gcode\stats\../../module/printcounter.h:25,
from Marlin\src\gcode\stats\M31.cpp:25:
Marlin\src\gcode\stats\../../module/../libs/duration_t.h:130:21: note: 'sprintf' output between 15 and 22 bytes into a destination of size 21
Compiling .pio\build\LPC1769\src\src\lcd\dogm\u8g_dev_st7920_128x64_HAL.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\dogm\u8g_dev_tft_320x240_upscale_from_128x64.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\dogm\u8g_dev_uc1701_mini12864_HAL.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\dogm\u8g_fontutf8.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\dogm\ultralcd_DOGM.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\dogm\ultralcd_st7920_u8glib_rrd_AVR.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\extui\anycubic_chiron_lcd.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\extui\anycubic_i3mega_lcd.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\extui\ui_api.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\fontutils.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\lcdprint.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\menu\menu.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\menu\menu_advanced.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\menu\menu_configuration.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\menu\menu_custom.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\menu\menu_game.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\menu\menu_main.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\menu\menu_media.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\menu\menu_mixer.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\menu\menu_motion.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\menu\menu_temperature.cpp.o
In file included from c:\users\stephen\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\10.3.1\functional:56,
from c:\users\stephen\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\10.3.1\pstl\glue_algorithm_defs.h:13,
from c:\users\stephen\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\10.3.1\algorithm:74,
from Marlin\src\lcd\../inc/../HAL/./LPC1768/HAL.h:35,
from Marlin\src\lcd\../inc/../HAL/HAL.h:26,
from Marlin\src\lcd\../inc/MarlinConfig.h:30,
from Marlin\src\lcd\lcdprint.h:35,
from Marlin\src\lcd\lcdprint.cpp:31:
c:\users\stephen\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\10.3.1\bits\functional_hash.h:168:3: error: redefinition of 'struct std::hash<long unsigned int>'
168 | _Cxx_hashtable_define_trivial_hash(unsigned long)
c:\users\stephen\.platformio\packages\toolchain-gccarmnoneeabi\arm-none-eabi\include\c++\10.3.1\bits\functional_hash.h:136:3: note: previous definition of 'struct std::hash<long unsigned int>'
136 | _Cxx_hashtable_define_trivial_hash(wchar_t)
Compiling .pio\build\LPC1769\src\src\lcd\menu\menu_tmc.cpp.o
Compiling .pio\build\LPC1769\src\src\lcd\menu\menu_tune.cpp.o
*** [.pio\build\LPC1769\src\src\lcd\lcdprint.cpp.o] Error 1
============================================================================================ [FAILED] Took 25.36 seconds ============================================================================================
Environment Status Duration
LPC1769 FAILED 00:00:25.358
======================================================================================= 1 failed, 0 succeeded in 00:00:25.358 =======================================================================================
The terminal process "C:\Users\stephen\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
