Hello guys, I’m trying to create a pure LoRa project using the 915MHz band between a Lopy4 (receiver) and a heltec ESP32 V2 (transmitter). I’m still learning about the settings, I just set the bandwidth and frequency setting and got some strange scenarios, I would like to share with you:
Did you notice that the sending of data is constant but the receipt is varied?
Is there a possibility to fix this problem?
I used: GitHub - Inteform/esp32-lora-library: Low-level Lora (SX127_) library for the ESP-32 IDF (Lib LoRa ESP-IDF to Heltec) and LoRa (Lopy4)
