Hi there. I am currently developing and thus have to re-compile my code quite offen. Here is how it goes:
- Fast progess until the depency graphs have been listed
- Quite long pause (>120s)
- Fast compilation, linking and upload
Here my compile log:
Executing task: C:\Users\wes39504.platformio\penv\Scripts\platformio.exe run --target upload
Processing firebeetle32 (platform: espressif32; board: firebeetle32; framework: arduino)
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/firebeetle32.html
PLATFORM: Espressif 32 (5.2.0) > FireBeetle-ESP32
HARDWARE: ESP32 240MHz, 520KB RAM, 16MB Flash
- framework-arduinoespressif32 @ 3.20005.220925 (2.0.5)
- tool-esptoolpy @ 1.40201.0 (4.2.1)
- tool-mkfatfs @ 2.0.1
LDF Modes: Finder ~ chain+, Compatibility ~ soft
Found 54 compatible libraries
|-- ArduinoJson @ 6.20.0
|-- Time @ 1.6.1
|-- Adafruit ADS1X15 @ 2.4.0
|-- Adafruit BusIO @ 1.14.1
|-- PubSubClient @ 2.8.0
|-- WiFi @ 2.0.0
|-- config_GPIO
|-- web_and_wifi
|-- NVS
|-- SD_control
|-- FS @ 2.0.0
|-- SD @ 2.0.0
|-- SPI @ 2.0.0
|-- system
|-- AWS
|-- WiFiClientSecure @ 2.0.0
|-- spiffs_config
|-- SPIFFS @ 2.0.0
|-- sleep
|-- FreqCountESP @ 1.0.0
|-- ADC
|-- Wire @ 2.0.0
|-- NTP_and_RTC
|-- Sensor
|-- OTA
|-- Update @ 2.0.0
|-- testing
**LONG PAUSE**
Compiling .pio\build\firebeetle32\src\system_control.cpp.o
Compiling .pio\build\firebeetle32\libed8\OTA\ota.cpp.o
Compiling .pio\build\firebeetle32\lib80f\Sensor\sensor.cpp.o
Compiling .pio\build\firebeetle32\lib39a\NTP_and_RTC\NTP_and_RTC.cpp.o
Compiling .pio\build\firebeetle32\libd11\ADC\ADC.cpp.o
Compiling .pio\build\firebeetle32\lib00c\spiffs_config\spiffs_config.cpp.o
Compiling .pio\build\firebeetle32\lib8cc\sleep\sleep.cpp.o
Compiling .pio\build\firebeetle32\libf23\AWS\aws_http.cpp.o
Archiving .pio\build\firebeetle32\lib80f\libSensor.a
Archiving .pio\build\firebeetle32\libed8\libOTA.a
Compiling .pio\build\firebeetle32\libf23\AWS\aws_mqtt.cpp.o
Archiving .pio\build\firebeetle32\lib39a\libNTP_and_RTC.a
Compiling .pio\build\firebeetle32\lib344\system\system.cpp.o
Compiling .pio\build\firebeetle32\lib140\SD_control\SD_control.cpp.o
Archiving .pio\build\firebeetle32\lib8cc\libsleep.a
Archiving .pio\build\firebeetle32\libd11\libADC.a
Compiling .pio\build\firebeetle32\lib346\NVS\my_nvs.cpp.o
Compiling .pio\build\firebeetle32\libd0c\web_and_wifi\web_and_wifi.cpp.o
Compiling .pio\build\firebeetle32\lib62f\testing\testing.cpp.o
Archiving .pio\build\firebeetle32\lib344\libsystem.a
Archiving .pio\build\firebeetle32\libf23\libAWS.a
Archiving .pio\build\firebeetle32\lib00c\libspiffs_config.a
Archiving .pio\build\firebeetle32\libd0c\libweb_and_wifi.a
Archiving .pio\build\firebeetle32\lib140\libSD_control.a
Archiving .pio\build\firebeetle32\lib346\libNVS.a
Archiving .pio\build\firebeetle32\lib62f\libtesting.a
Linking .pio\build\firebeetle32\firmware.elf
Retrieving maximum program size .pio\build\firebeetle32\firmware.elf
Checking size .pio\build\firebeetle32\firmware.elf
RAM: [= ] 8.9% (used 47148 bytes from 532480 bytes)
Flash: [== ] 16.9% (used 1109917 bytes from 6553600 bytes)
Building .pio\build\firebeetle32\firmware.bin
esptool.py v4.2.1
Creating esp32 image...
Merged 25 ELF sections
AVAILABLE: cmsis-dap, esp-bridge, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port...
Auto-detected: COM1
Uploading .pio\build\firebeetle32\firmware.bin
esptool.py v4.2.1
Serial port COM1
Some more info:
- This is my PlatformIO version: PlatformIO 6.1.7a4
- During the “long pause” I am also able to make changes to the code and these changes get compiled. I tested with some print statements.
- I noticed this behavior on different Windows 10 machines
Any idea what can cause the long pause and how to improve it?
