LOLIN V3 ESP8266MOD 12-F no connection possible
Hi there, yesterday I connected first time a ESP8266 to PlatformIO in Visual Studio For Code.
Times before, I was working withan Arduino Nano, without problems, all works fine (compiling, upload).
But yesterday with the ESP8266, I used NodeMCUV1.0 12-E as board, compiling was ok, but upload was not possible. I tried it also with Arduino IDE, there wasn’t it possible. I get following error in Arduino but in PIO was the same error:
. Variables and constants in RAM (global, static), used 28100 / 80192 bytes (35%)
║ SEGMENT BYTES DESCRIPTION
╠══ DATA 1496 initialized variables
╠══ RODATA 924 constants
╚══ BSS 25680 zeroed variables
. Instruction RAM (IRAM_ATTR, ICACHE_RAM_ATTR), used 59747 / 65536 bytes (91%)
╠══ ICACHE 32768 reserved space for flash instruction cache
╚══ IRAM 26979 code in IRAM
. Code in flash (default, ICACHE_FLASH_ATTR), used 236292 / 1048576 bytes (22%)
╚══ IROM 236292 code in flash
esptool.py v3.0
Serial port COM8
A fatal esptool.py error occurred: Cannot configure port, something went wrong. Original message: PermissionError(13, ‘Ein an das System angeschlossenes Ger�t funktioniert nicht.’, None, 31)
Has someone an idea? I think the drive should be well, because wiht Arduino Nano was no problem.
Is there a problem with the esptool.py in python ??
Board or Windows driver is fried.
Try reinstalling known-good drivers for the usb-to-serial converter on your board, likely a CH340 or a CP2102.
