I have a platformio project that compiles and works. I decided to refactor and move to files logger.h and logger.cpp from an existing library directory lib/misc to a new library directory lib/logger. When I try to build, platformio detects the dependency on the new library lib/logger but #include “logger.h”, which previously used to work, fails. More information below.
Any idea what the problem may be?
Error message:
#include <logger.h>
compilation terminated.
In file included from lib\io\serial.h:6:0,
from lib\io\serial.cpp:1:
lib\misc/common.h:9:10: fatal error: logger.h: No such file or directory
platformio.ini (it contains a few library related directives such as lib_ldf_mode):
[env:my_env]
platform = ststm32
; test_filter = serial_packets/test_serial_packets_client
; debug_test = serial_packets/test_serial_packets_client
extra_scripts = extra_script.py
board = my_genericSTM32H750VBT6
; Linker file is from cube ide.
board_build.ldscript = STM32H750VBTX_FLASH.ld
debug_tool = stlink
upload_protocol = stlink
debug_build_flags = -Os -g3 -ggdb3
; debug_init_break = tbreak app_main
debug_init_break = tbreak none
test_framework = unity
test_port = COM6
monitor_port = COM6
lib_archive = no
check_skip_packages = yes
lib_ldf_mode=deep
# cube_ide is automatically populated by cube_ide/update_platformil.py
# startup contains the processor startup code and is based on
# cube_ide/core/src/main.c. The rest of the libraries are detected
# automatically.
cube_ide
startup
-fmax-errors=5
-Werror
-mfpu=fpv5-sp-d16
-mfloat-abi=hard
-Wl,-Map,${BUILD_DIR}/firmware.map
-mthumb
-D DEBUG
-D USE_HAL_DRIVER
-DSTM32_THREAD_SAFE_STRATEGY=4
-fstack-usage
-std=gnu11
-Ilib/cube_ide/Core/Inc
-Ilib/cube_ide/Core/ThreadSafe
-Ilib/cube_ide/Drivers/CMSIS/Device/ST/STM32H7xx/Include
-Ilib/cube_ide/Drivers/CMSIS/Include
-Ilib/cube_ide/Drivers/STM32H7xx_HAL_Driver/Inc
-Ilib/cube_ide/Middlewares/ST/STM32_USB_Device_Library/Class/CDC/Inc
-Ilib/cube_ide/Middlewares/ST/STM32_USB_Device_Library/Core/Inc
-Ilib/cube_ide/Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS
-Ilib/cube_ide/Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS_V2/Include
-Ilib/cube_ide/Middlewares/Third_Party/FreeRTOS/Source/include
-Ilib/cube_ide/Middlewares/Third_Party/FreeRTOS/Source/portable/GCC/ARM_CM4F
-Ilib/cube_ide/Middlewares/Third_Party/FatFs/src
-Ilib/cube_ide/USB_DEVICE/App
-Ilib/cube_ide/USB_DEVICE/Target
-Ilib/cube_ide/FATFS/App
-Ilib/cube_ide/FATFS/Target
-D CONFIG_MAX_PACKET_DATA_LEN=1000
-D CONFIG_MAX_PENDING_COMMANDS=5
Build log (I do see ‘-Ilib\logger’ in the gcc command line):
$ pio run -vvvProcessing my_env (platform: ststm32; extra_scripts: extra_scrip - Pastebin.com (long)
The directory tree of my project:
+---.pio
| +---build
| | \---my_env
| | +---lib2be
| | | \---misc
| | +---lib3f1
| | | \---startup
| | +---lib48e
| | | \---host_link
| | +---lib4fd
| | | \---controller
| | +---lib50d
| | | \---io
| | +---lib7e9
| | | \---logger
| | +---libd5d
| | | \---data_recorder
| | +---libe47
| | | \---cube_ide
| | | +---Core
| | | | +---Src
| | | | +---Startup
| | | | \---ThreadSafe
| | | +---Drivers
| | | | \---STM32H7xx_HAL_Driver
| | | | \---Src
| | | +---FATFS
| | | | +---App
| | | | \---Target
| | | +---Middlewares
| | | | +---ST
| | | | | \---STM32_USB_Device_Library
| | | | | +---Class
| | | | | | \---CDC
| | | | | | \---Src
| | | | | \---Core
| | | | | \---Src
| | | | \---Third_Party
| | | | +---FatFs
| | | | | \---src
| | | | | \---option
| | | | \---FreeRTOS
| | | | \---Source
| | | | +---CMSIS_RTOS
| | | | \---portable
| | | | \---GCC
| | | | \---ARM_CM4F
| | | \---USB_DEVICE
| | | +---App
| | | \---Target
| | \---libee8
| | \---serial_packets
| \---libdeps
| \---my_env
+---.vscode
+---boards
+---lib
| +---adc
| +---controller
| +---cube_ide
| | +---Core
| | | +---Inc
| | | +---Src
| | | +---Startup
| | | \---ThreadSafe
| | +---Drivers
| | | +---CMSIS
| | | | +---Device
| | | | | \---ST
| | | | | \---STM32H7xx
| | | | | +---Include
| | | | | \---Source
| | | | | \---Templates
| | | | \---Include
| | | +---Inc
| | | | \---Legacy
| | | \---Src
| | +---FATFS
| | | +---App
| | | \---Target
| | +---Middlewares
| | | +---ST
| | | | +---Class
| | | | | \---CDC
| | | | | +---Inc
| | | | | \---Src
| | | | \---Core
| | | | +---Inc
| | | | \---Src
| | | \---Third_Party
| | | +---FatFs
| | | | \---src
| | | | \---option
| | | \---FreeRTOS
| | | \---Source
| | | +---CMSIS_RTOS
| | | +---include
| | | \---portable
| | | \---GCC
| | | \---ARM_CM4F
| | \---USB_DEVICE
| | +---App
| | \---Target
| +---data_recorder
| +---host_link
| +---io
| +---logger
| +---misc
| +---printer_link
| +---rtos_util
| +---serial_packets
| \---startup
+---src
+---test
| +---misc
| | +---test_static_string
| | \---test_time_util
| +---sd
| | \---test_rw
| +---serial_packets
| | +---test_serial_packets_client
| | +---test_serial_packets_crc
| | +---test_serial_packets_data
| | +---test_serial_packets_decoder
| | \---test_serial_packets_encoder
| +---test_sample
| +---test_trivial
| \---__pycache__
\---tools
