Hey,
I used to use the arduino ide 2.0
Since a few weeks I’m using platform IO and I like it a lot
But a strange behaviour comes to me when using littlefs.
#include <LittleFS.h>
I got the following error
Looking for LittleFS.h dependency? Check our library registry!
Listing directory: /
FILE: test.txt SIZE: 0 LAST WRITE: 1970-01-01 00:00:00
Creating Dir: /mydir
Dir created
Writing file: /mydir/hello2.txt
file written
Create missing folders of: /mydir/newdir2/newdir3/hello3.txt
Writing file to: /mydir/newdir2/newdir3/hello3.txt
file written
DIR : mydir LAST WRITE: 1969-12-31 23:59:59
Listing directory: mydir
failed to open directory
Deleting file: /mydir/hello2.txt
file deleted
Deleting file and empty folders on path: /mydir/newdir2/newdir3/hello3.txt
file deleted
Removing all empty folders on path: /mydir/newdir2/newdir3/hello3.txt
Removing Dir: /mydir
rmdir failed
Writing file: /hello.txt
file written
Appending to file: /hello.txt
message appended
Reading file: /hello.txt
read from file:
Hello World!
Renaming file /hello.txt to /foo.txt
file renamed
Reading file: /foo.txt
read from file:
Hello World!
Deleting file: /foo.txt
file deleted
Testing file I/O with /test.txt
writing…/components/esp_littlefs/src/littlefs/lfs.c:561:error: No more free space 77
./components/esp_littlefs/src/littlefs/lfs.c:561:error: No more free space 77
It’s surprising, but in this case I will use SPIFFS because it’s straigt forward to use and when it completly replaced with littlefs I’m changing the code
