Hi it’s been a few days am on this and I have no clue what is going on. I am using the LIS3DH library in VS Code (dowloaded from PIO) and the code below.
Accel class in one file
#include "Arduino.h"
#include "Accel.h"
// Used for software SPI
#define LIS3DH_CLK 27
#define LIS3DH_MISO 39
#define LIS3DH_MOSI 26
// Used for hardware & software SPI
#define LIS3DH_CS 37
// software SPI
Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS, LIS3DH_MOSI, LIS3DH_MISO, LIS3DH_CLK);
Accel::Accel()
delay(5000);
Serial.println("LIS3DH test!");
if (!lis.begin(0x18))
{ // change this to 0x19 for alternative i2c address
Serial.println("Couldnt start ACCEL");
while (1)
yield();
// lis.setDataRate(LIS3DH_DATARATE_50_HZ);
Serial.print("Data rate set to: ");
switch (lis.getDataRate())
case LIS3DH_DATARATE_1_HZ:
Serial.println("1 Hz");
break;
case LIS3DH_DATARATE_10_HZ:
Serial.println("10 Hz");
break;
case LIS3DH_DATARATE_25_HZ:
Serial.println("25 Hz");
break;
case LIS3DH_DATARATE_50_HZ:
Serial.println("50 Hz");
break;
case LIS3DH_DATARATE_100_HZ:
Serial.println("100 Hz");
break;
case LIS3DH_DATARATE_200_HZ:
Serial.println("200 Hz");
break;
case LIS3DH_DATARATE_400_HZ:
Serial.println("400 Hz");
break;
case LIS3DH_DATARATE_POWERDOWN:
Serial.println("Powered Down");
break;
case LIS3DH_DATARATE_LOWPOWER_5KHZ:
Serial.println("5 Khz Low Power");
break;
case LIS3DH_DATARATE_LOWPOWER_1K6HZ:
Serial.println("16 Khz Low Power");
break;
xvar = 0;
yvar = 0;
zvar = 0;
void Accel::acquire()
lis.read();
// Serial.print("fin accel : ");
// Serial.println(micros());
sensors_event_t event;
lis.getEvent(&event);
xvar = event.acceleration.x;
yvar = event.acceleration.y;
zvar = event.acceleration.z;
Accel.h file
#ifndef Accel_h
#define Accel_h
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_LIS3DH.h>
#include <Adafruit_Sensor.h>
class Accel
public:
Accel();
void acquire();
void setaccelpin(int accelpin);
int getaccelpin();
float xvar;
float yvar;
float zvar;
Main file
#include "Accel.h"
Accel _Accel;
void setup()
Serial.begin(9600);
Serial.print("Start");
void loop()
_Accel.acquire();
Serial.println(_Accel.xvar);
Every time I run this it is stuck in “could’nt start accel” however the pins are the correct one cause when I run this in Arduino with the library installed with the library manager it works fine.
Any idea what this could be ?
