I am trying to install the library LiquidMenu however I get the error:
.pio/libdeps/nanoatmega328new/LiquidMenu/src/LiquidMenu.h:53:10: fatal error: LiquidCrystal.h: No such file or directory
I can fix this error by updating the line in LiquidMenu.h as below:
#include <…/…/LiquidCrystal/LiquidCrystal.h>
However I was wondering if I have installed the library correctly as I would rather not need to modify the downloaded library source code…?
Also I have tried all the different lib_ldf_mode settings such as ‘deep+’ but that did not help.
Thanks,
Alex.
Good question – it looks like you found a bug. I’m trying this with
[env:uno]
board = uno
; select liquidcrystal library (1) instead of the I2C version (2)
build_flags = -DLIQUIDMENU_LIBRARY=1
vase7u/LiquidMenu@^1.6.0
fmalpartida/LiquidCrystal@^1.5.0
Wire
lib_ldf_mode = deep+
and the dependency is still not recognized.
|-- <LiquidMenu> 1.6.0
|-- <LiquidCrystal> 1.5.0
| |-- <Wire> 1.0
|-- <Wire> 1.0
(LiquidMenu should have LiquidCrystal as a sub-dependency).
This is likely due to the way the libary is included with the conditionals.
This sort of defines seems to overwhelm the detection logic.
I will open a bug about this.
Thank you for your quick response, good to know I installed the library correctly as I am quite new to platformio coming from arduino ide.
