I do not understand why #include <LiquidCrystal.h> is not found.
I follow the quick start and set the platformio.ini. Then include the corresponding header in main.cpp
When it’s not working the quick start guide indicate to run this command:
“Menu: View > Command Palette… > PlatformIO: Rebuild C/C++ Project Index”
But it does not exist, I found only : Platformio: Rebuild Intellisense Index Which I run.
Still same result.
EDIT:
The program build and can be download to the arduino. With hazardous behaviour. Sometimes, the screen stay blank, sometimes the letter “w” fill the screen.
The same program copy and past to the “Arduino IDE”, without the include <Arduino.h>, works perfectly.
Yes, it builds. I update my answer to add more information. Thanks for the question.
If it builds the headers must be found. Try executing Ctrl+Shift+P → Rebuild IntelliSense again.
Also, the version of the LiquidCrystal library you’re using comes from author fmalpartida, which doesn’t seem to be the ‘official’ one and may behave differently. You may want the standard Arduino one via
arduino-libraries/LiquidCrystal @ ^1.0.7
as per this.
I tried with the version you proposed too. The one I show at first is the one proposed by vscode when looking for “LiquidCrystal” Library.
It is still not working. Here all the steps done starting with a new project:
- new project from PIO Home
- Choose:
- Board: Arduino Uno
- Framework: Arduino
- Search libraries from PIO HOme
- do not choose the first library
- choose: “LiquidCrystal” by Arduino
- click on “Add to Project”
- which install the same library used within Arduino IDE
- Executing Ctrl+Shift+P →
- add
#include <LiquidCrystal.h> in main.cpp => error rise
- try to get ride off this error with no success:
- restart vscode
- add “hello world” code:
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// set up the number of columns and rows on the LCD
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print(“Hello World”);
- build successful:
>Executing task in folder Theremine Lumineux: platformio run
Processing uno (platform: atmelavr; board: uno; framework: arduino)
CONFIGURATION: Redirecting...
PLATFORM: Atmel AVR (3.3.0) > Arduino Uno
- framework-arduino-avr 5.1.0
Found 5 compatible libraries
Scanning dependencies…
Checking size .pio/build/uno/firmware.elf
RAM: [= ] 10.2% (used 208 bytes from 2048 bytes)
Flash: [= ] 12.2% (used 3940 bytes from 32256 bytes)
==================== [SUCCESS] Took 0.81 seconds============
- upload successful:
Configuring upload protocol…
AVAILABLE: arduino
Looking for upload port…
Auto-detected: /dev/ttyACM0
Uploading .pio/build/uno/firmware.hex
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file “.pio/build/uno/firmware.hex”
avrdude: writing flash (3940 bytes):
Writing | ################################################## | 100% 0.64s
avrdude: 3940 bytes of flash written
avrdude: verifying flash memory against .pio/build/uno/firmware.hex:
avrdude: load data flash data from input file .pio/build/uno/firmware.hex:
avrdude: input file .pio/build/uno/firmware.hex contains 3940 bytes
Reading | ################################################## | 100% 0.51s
avrdude: verifying …
avrdude: 3940 bytes of flash verified
avrdude: safemode: Fuses OK (E:00, H:00, L:00)
avrdude done. Thank you.
===================== [SUCCESS] Took 3.20 seconds =================
- result on arduino: only “w” letters and few “PI” letters
- load the same program from arduino IDE: “Hello world” appears on the LCD screen
- reload from vscode: the letter “w” is writen after “Hello world” and then recover it!!!
- tried with differents text loading from “arduino IDE” and then from vscode. Loading from vscode will always result by some “w” filling the screen. Sometime it also erase the previous message.
I just realize that the compilation is not done for the current opened project but for another one!
I also manage to “solve” the issue on “include” doing the following:
- copy/past the LiquidCrystal library in
include folder
- add in the code :
#include “LiquidCrystal/src/LiquidCrystal.h”
Now, I’m looking for how to build the current opened file. And check if that could have solved the “include ussue” here without having to copy/past the library.
Aha okay thath sounds more likely, I was just about to test this on my own hardware.
Please use the project environment switcher to select the project + environment. Building is not done on the currently opened file and cannot be set to do so.
Thanks for your time and apologize. I just discover the “project environment switcher”, minutes ago. A petty I did not see your answer earlier.
Pointing at the correct project solve all the issues. I removed the library from the include folder.
Thanks again.
