Hey there,
I have a little problem and don’t really know where it comes from.
I’m using PIO with the esp-prog and an ESP32.
Since today everytime I start debugging the JTAG tty-device gets disconnected…
[ 1600.030259] ftdi_sio 1-14:1.1: device disconnected
[ 1600.338307] usb 1-14: new high-speed USB device number 19 using xhci_hcd
[ 1600.503975] usb 1-14: New USB device found, idVendor=0403, idProduct=6010
[ 1600.503977] usb 1-14: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1600.503979] usb 1-14: Product: Dual RS232-HS
[ 1600.503980] usb 1-14: Manufacturer: FTDI
[ 1600.511720] ftdi_sio 1-14:1.0: FTDI USB Serial Device converter detected
[ 1600.511751] usb 1-14: Detected FT2232H
[ 1600.516384] usb 1-14: FTDI USB Serial Device converter now attached to ttyUSB0
[ 1600.519017] ftdi_sio 1-14:1.1: FTDI USB Serial Device converter detected
[ 1600.519044] usb 1-14: Detected FT2232H
[ 1600.524382] usb 1-14: FTDI USB Serial Device converter now attached to ttyUSB1
[ 1741.346396] usb 1-14: USB disconnect, device number 19
[ 1741.346559] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[ 1741.346582] ftdi_sio 1-14:1.0: device disconnected
[ 1741.346700] ftdi_sio ttyUSB1: FTDI USB Serial Device converter now disconnected from ttyUSB1
[ 1741.346718] ftdi_sio 1-14:1.1: device disconnected
So I already checked if all user groups are set correctly and also my platformio.ini but everything seems fine.
The two ports are also displayed in PIO as long as I don’t start debugging.
PIO itself gives me the following:
Preparing firmware for debugging...
Processing az-delivery-devkit-v4:debug (board: az-delivery-devkit-v4; framework: arduino; platform: espressif32)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/az-delivery-devkit-v4.html
PLATFORM: Espressif 32 (2.0.0) > AZ-Delivery ESP-32 Dev Kit C V4
HARDWARE: ESP32 240MHz, 520KB RAM, 16MB Flash
- framework-arduinoespressif32 3.10004.201016 (1.0.4)
Found 31 compatible libraries
|-- <U8g2> 2.28.6
| |-- <SPI> 1.0
| |-- <Wire> 1.0.1
|-- <Arduino_JSON> 0.1.0
|-- <ESP32AnalogRead> 0.0.5
|-- <HTTPClient> 1.2
| |-- <WiFi> 1.0
| |-- <WiFiClientSecure> 1.0
| | |-- <WiFi> 1.0
|-- <MFRC522>
| |-- <SPI> 1.0
|-- <SPI> 1.0
|-- <WiFi> 1.0
|-- <Wire> 1.0.1
Building in debug mode
Retrieving maximum program size .pio/build/az-delivery-devkit-v4:debug/firmware.elf
Checking size .pio/build/az-delivery-devkit-v4:debug/firmware.elf
RAM: [= ] 7.9% (used 41840 bytes from 532480 bytes)
Flash: [======= ] 72.7% (used 953326 bytes from 1310720 bytes)
========================= [SUCCESS] Took 3.17 seconds =========================
Environment Status Duration
az-delivery-devkit-v4:debug SUCCESS 00:00:03.173
========================= 1 succeeded in 00:00:03.173 =========================
undefinedOpen On-Chip Debugger v0.10.0-esp32-20190708 (2019-07-08-11:03)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
Info : Configured 2 cores
esp32 interrupt mask on
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Reading symbols from /media/jan-niklas/Data/Daten/Arduino/PlatformIO Projects/DLA_client_ESP32_MT/.pio/build/az-delivery-devkit-v4:debug/firmware.elf...
done.
PlatformIO: debug_tool = esp-prog
/dev/ttyUSB0: Datei oder Verzeichnis nicht gefunden. (File or Dir not found)
I hope someone has an idea where to look for the problem.
JNB
