I am using Visual Studio Code 1.43.0 with:
Extensions (only 2):
- PlatformIO IDE 1.10.0 Core 4.3.0b1 Home 3.3.1
- C / C ++ 0.26.3
in Windows 10 Home version 1809
I have 2 problems (maybe related).
The first problem - linter only works when building a project.
The second problem - warnings are only shown on the first build after cleaning (in the PlatformIO project tasks) or when I change sth in the code (there is no compilation on secound build - no wornings).
For example:
- First build…
Compiling .pio\build\d1_mini\src\main.cpp.o
src\main.cpp: In function ‘void setup()’:
src\main.cpp:5:9: warning: array subscript is above array bounds [-Warray-bounds]
test[5]= ‘g’;
… - Next builds:
Retrieving maximum program size .pio\build\d1_mini\firmware.elf
Moreover, when there is error in code warnnings are not shown.
I can’t find any solution (checkd settings, reinstalled vsc and PlatformIO).
Please help.
