Hello and thanks for PlatformIO!
I am coding my first Arduino project in C++. It seems to be compiling correctly when I put all code in one file. However, when I divide my program in multiple files, I get the following error message:
*** [.pioenvs/uno/firmware.elf] Error 1
The complete output can be found here:
The whole project is on github:
https://github.com/speendo/AutomaticMorse-A-Com/tree/withoutTemplates
Probably it’s some basic error I’m making, however, I can’t find it.
Can you help me?
Thank you in advance!
You do weird stuff in there. E.g. in InputSignal.cpp
, you declare the class and start implementing functions as
#include "SignalStorage.hpp"
class InputSignal {
const unsigned int waitMs;
const unsigned int minEventMs;
const unsigned int maxSigMs;
bool signal;
bool prevSignal;
bool error;
bool listening;
unsigned long validEventMs;
unsigned long lastEventMs;
SignalStorage signalStorage;
public:
InputSignal(unsigned int waitMs, unsigned int minEventMs, unsigned int maxSigMs, SignalStorage signalStorage) :
waitMs(waitMs),
minEventMs(minEventMs),
maxSigMs(maxSigMs),
signalStorage(signalStorage)
reset();
but then in InputSignal.hpp
you declare it all over again?
#ifndef InputSignal_hpp
#define InputSignal_hpp
class InputSignal {
public:
InputSignal(unsigned int waitMs, unsigned int minEventMs, unsigned int maxSigMs);
void setup();
void loop();
void reset();
bool getError();
protected:
bool getSmoothSignal();
virtual bool getSignal();
You must put your class declarations in the hpp
file and the definitions/implementations in the cpp
file without re-declaring the entire class again. They also have completely different definitions of the same functions like the constructor.
hpp:
cpp:
InputSignal::InputSignal(unsigned int waitMs, unsigned int minEventMs, unsigned int maxSigMs, SignalStorage signalStorage)
Thus it’s impossible to know what you’ve actually meant.
A starting point would be to read https://www.learncpp.com/cpp-tutorial/89-class-code-and-header-files/ and follow the style starting at " Putting class definitions in a header file"
Thank you for looking at it in such a detailed manner.
To be honest, I didn’t understand header files at all. Coming from Java, I didn’t know what their purpose was.
The tutorial you mentioned cleared things up a little bit. I will try to replicate this knowledge in my project and report back if everything works as intended.
Thank you once more!
Thank you!
That solved my problem… at least this one
