Dear all
I am currently working on a project for a controller board (ESP32-based) where all the peripherals are abstracted using “Hardware Managers” which then are merged and controlled by a “Wrapper” library. This way, I can call specific peripherals and execute intricate actions using a single line (in theory). Please note that I am trying to hide the actual name of my project by replacing sensitive names using xxx while trying to keep a logical naming convention to convey my case.
I have successfully completed the design of this wrapper and peripherals managers on a VSCode+pio project following the recommended folder organization. This was done on a “barebones” approach by having all dependencies and libraries inside the lib/ folder, as shown in this project structure:
where I implemented a bunch of envs to have manual control over the compilation of specific files, including tests and examples. The working `platform.ini" file looks something like this (partially):
[env_defaults]
build_type = release
upload_speed = 921600
Wire
adafruit/Adafruit BusIO@^1.17.0
board_upload.flash_size = 16MB
-I/lib/xxx_Controller (see note)
-I/lib/Adafruit_HUSB238
-I/lib/EEPROM_UID
-I/lib/I2C_EEPROM
-I/lib/MCP23017_RT
-I/lib/RTClib
-I/lib/SD
-I/lib/modbus-esp8266/src
-I/lib/TCA9548
-I/lib/PCA9632
-DBOARD_HAS_PSRAM
-O3
lib_ldf_mode = deep+
[env:eeeprom_uid_test]
extends = env_defaults
build_src_filter = +<EEPROMUIDTest/>
Note: The first build_flag calls “lib/xxx_Controller” whilst the filename is “xxx_Controller_Wrapper.h”, however the class is: “class xxx_Controller”. Apologies for this small inconsistency, I did not notice this until now since everything compiles just fine.
Now, here is where the linking errors occur and please bear with me.
For the sake of portability (internal in my organization), I decided to “pack” my solution into a GitHub repository where the managers headers and source files are places inside include and src folders, respectively and the external libraries used by the managers are contained as submodules inside a nested lib/ folder so that everything needed for development is held within the same wrapper repo with the following structure:
Wrapper_Controller
|–examples
| |–Example_Manager1
| |–Example_Manager2
| |–…etc
|–include {contains all .h files}
| |–Wrapper_Controller.h
| |–Manager1.h
| |–Manager2.h
| |–…etc
|–src {contains all .cpp files}
| |–Wrapper_Controller.cpp
| |–Manager1.cpp
| |–Manager2.cpp
| |–…etc
|–lib {contains all git submodules}
| |–Submodule1
| |–Submodule2
| |–Submodule3
| |–…etc
I cloned this repository inside the `lib’ folder from a new project where I plan to continue the development of the controller firmware (where I will use the wrapper and other libraries) as well as work on corrections of the same wrapper code.
My new project structure using the GitHub repo looks like this:
One of my several attempts to configure an .ini file is this:
lib_deps = adafruit/Adafruit BusIO@^1.17.0
; If using submodules, ensure the submodule is pulled correctly
lib_extra_dirs = lib/xxx_Wrapper_Controller/lib
-I lib/xxx_Wrapper_Controller/include
-I lib/xxx_Wrapper_Controller/lib/Adafruit_HUSB238
-I lib/xxx_Wrapper_Controller/lib/EEPROM_UID
-I lib/xxx_Wrapper_Controller/lib/I2C_EEPROM
-I lib/xxx_Wrapper_Controller/lib/MCP23017_RT
-I lib/xxx_Wrapper_Controller/lib/RTClib/src
-I lib/xxx_Wrapper_Controller/lib/SD
-I lib/xxx_Wrapper_Controller/lib/SdFat-Adafruit-Fork
-I lib/xxx_Wrapper_Controller/lib/modbus-esp8266/src
-I lib/xxx_Wrapper_Controller/lib/TCA9548
-I lib/xxx_Wrapper_Controller/lib/PCA9632
-DBOARD_HAS_PSRAM
-O3
My project “parses” correctly. I can use the context menus and navigate to all source and header files using the options “Go to definitions” and “Go to declaration” There are no squiggly lines anywhere in the code, however, I get tons of linking issues, something along the lines of:
“Undefined reference to: Manager1::method1…”
“Undefined reference to: Manager2::methodN”
“Undefined reference to: xxx_Wrapper::Constructor”
"“Undefined reference to: xxx_Wrapper::~Destructor”
which makes me think that I am missing something to point pio to the source files.
I have tried moving all .h files together with the .cpp files inside the src/ folder, however, the problems persist.
I have also tried including the src/ folder in the build_flags as:
build_flags = -I lib/xxx_Wrapper_Controller/src
Please note that all submodules are present and have been initialised.
I would appreciate any pointers (no pun intended), suggestions and comments.
Perhaps I need to rethink my folder structure, right?
Cheers
EDIT: My solution does include a library.json file inside the cloned wrapper library, however, I am not sure how impactful it is for a successful compilation.
UPDATE 1: I have tried EVERY solution I have come across on the forum to no avail. I have moved the .cpp files along with the .h files inside the src/ folder from the rapper library. After doing this, I faced EXACTLY the same issue reported here regarding Adafruit_I2CDevice.h missing in one of my managers. I added such header to the manager and the linking issues returned. It is important to emphasize that this issue did NOT occur in my previous development with all the files exposed inside the lib/ folder.
I can confirm that the verbose compilation output shows that NONE of the .cpp files from my solution gets compiled since I cannot see any xxx.cpp.o file from my custom library and managers.
UPDATE 2: My issue and situation seem to be closely related to the one described in this thread where the user worked on a similarly nested project. There, the solution provided by @maxgerhardt (if I understood correctly) was to bring all source files to the root of the lib folder. However, in my case, this is not possible since my library is a git repo and the “nested libraries” are part or it (as submodules). I will try putting all files at the root of the wrapper library and report back shortly.
UPDATE 3 (Succes!(?)): Without moving any file and leaving my wrapper library “as is” I managed to get all .cpp files to compile and linking is now working!
This is my updated .ini file:
build_src_filter =
+<**/*.cpp>
+<lib/xxx_Wrapper_Controller/lib/*.cpp>
-I lib/xxx_Wrapper_Controller/lib/SdFat-Adafruit-Fork/src
-DBOARD_HAS_PSRAM
-O3
Wire
SPI
Now I wonder if these settings make any sense and if the compilation is accurate (yeah I am a bit paranoid now. I have spent too much time on this
) I strongly believe that the lines: lib_ldf_mode and build_src_filter were the trick that saved my project,
My final question is: How do I convert these latest additions into configuration settings inside the library.json so that any project that uses my wrapper compiles without having to add them on each ini file?
