When just using this simple line of Code, I get an linker error. Am I missing something? Can’t I use std::string in this context?
#include <string>
std::string b = "abc"; //linker error
Output from platformio run
[Fri Mar 23 11:51:29 2018] Processing teensy36 (platform: teensy; board: teensy36; framework: arduino)
PLATFORM: Teensy > Teensy 3.6
SYSTEM: MK66FX1M0 180MHz 256KB RAM (1MB Flash)
DEBUG: CURRENT(jlink) EXTERNAL(jlink)
LDF MODES: FINDER(chain) COMPATIBILITY(light)
Collected 95 compatible libraries
Compiling .pioenvs/teensy36/src/main.cpp.o
Linking .pioenvs/teensy36/firmware.elf
/home/marc/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/lib/armv7e-m/fpu/libc.a(lib_a-writer.o): In function `_write_r':
writer.c:(.text._write_r+0x12): undefined reference to `_write'
*** [.pioenvs/teensy36/firmware.elf] Error 1
My platformio.ini
[env:teensy36]
platform = teensy
board = teensy36
Platform information:
teensy ~ Teensy
Teensy is a complete USB-based microcontroller development system, in a very small footprint, capable of implementing many types of projects. All programming is done via the USB port. No special programmer is needed, only a standard USB cable and a PC or Macintosh with a USB port.
Version: 3.0.1
Home: http://platformio.org/platforms/teensy
Repository: https://github.com/platformio/platform-teensy.git
Vendor: https://www.pjrc.com/teensy
License: Apache-2.0
Frameworks: arduino, mbed
Packages
Package toolchain-atmelavr
Type: toolchain
Requirements: ~1.40902.0
Installed: Yes
Version: 1.40902.0
Original version: 4.9.2
Description: avr-gcc
Package framework-arduinoteensy
Type: framework
Requirements: ~1.141.0
Installed: Yes
Version: 1.141.0
Original version: 1.41
Description: Arduino Wiring-based Framework (Teensy Core)
Package tool-teensy
Type: uploader
Requirements: <2
Installed: Yes
Version: 1.141.0
Description: Teensy Loader
Package toolchain-gccarmnoneeabi
Type: toolchain
Requirements: ~1.50401.0
Installed: Yes
Version: 1.50401.0
Original version: 5.4.1
Description: gcc-arm-embedded
Package framework-mbed
Type: framework
Requirements: ~4.50703.0
Installed: No (optional)
Boards
ID MCU Frequency Flash RAM Name
teensy35 MK64FX512 120MHz 512KB 192KB Teensy 3.5
teensy20 ATMEGA32U4 16MHz 31.50KB 2.50KB Teensy 2.0
teensy36 MK66FX1M0 180MHz 1MB 256KB Teensy 3.6
teensy31 MK20DX256 72MHz 256KB 64KB Teensy 3.1 / 3.2
teensy30 MK20DX128 48MHz 128KB 16KB Teensy 3.0
teensylc MKL26Z64 48MHz 62KB 8KB Teensy LC
teensy20pp AT90USB1286 16MHz 127KB 8KB Teensy++ 2.0
