I have 2 Arduino Teensy projects: basicTestLibrary and legacyTest
basicTestLibrary is is a simple cpp and header combo with a Foo class inside Bar namespace. It has a single method: doSomething.
The legacyTest uses basicTestLibrary as a dependency linked via file://
The doSomething method is invoked in the default loop area of main.cpp in legacyTest
When I attempt to build the project, it fails with a linker error and undefined reference to Bar::Foo::doSomething(int)
I’ve had this same error on a larger project, which is why I created this test environment with a fresh install of VS Code and PlatformIO extension on a new Windows 10 VM. The issue persists.
Project download: Microsoft OneDrive
basicTestLibrary
platformio.ini
[env:teensy41]
platform = teensy
board = teensy41
library.json
"$schema": "https://raw.githubusercontent.com/platformio/platformio-core/develop/platformio/assets/schema/library.json",
"name": "basicTestLibrary",
"version": "0.1.0",
"authors": {
"name": "Matthew Baker",
"email": "",
"maintainer": true
"dependencies": {
"frameworks": ["arduino"],
"platforms": "*",
"build": {
"flags": [
"srcFilter": [
"-<main.cpp>"
legacyTest
platformio.ini
[common]
lib_deps_builtin =
lib_deps_external =
basicTestLibrary=file://C:/platform_io_projects/basicTestLibrary
[env]
platform = teensy
board = teensy40
lib_deps = ${common.lib_deps_builtin}
${common.lib_deps_external}
build_flags = -Wall
[env:teensy41]
platform = teensy
board = teensy41
Any ideas why this is happening?
#include "foo.h"
namespace Bar
Foo::Foo() {};
int doSomething(int x)
return x + 10;
Wrong.
The doSomething function is declared inside the namespace Bar, but not as a member method of the Foo class, as the header file declares.
namespace Bar
class Foo
public:
Foo();
int doSomething(int x);
So the foo.cpp has to be
#include "foo.h"
namespace Bar
Foo::Foo() {};
int Foo::doSomething(int x)
return x + 10;
Further, the libray.json is wrong. The srcFilter
"build": {
"flags": [
"srcFilter": [
"-<main.cpp>"
prevents all files of the library to be built. If you meant to say “build all files but the main.cpp” (which doesn’t even exist in that library’s folder?), then that’s
"+<*> -<main.cpp>"
Apply these fixes and you get
Linking .pio\build\teensy41\firmware.elf
Checking size .pio\build\teensy41\firmware.elf
Calculating size .pio\build\teensy41\firmware.elf
teensy_size: Memory Usage on Teensy 4.1:
teensy_size: FLASH: code:8984, data:3016, headers:8476 free for files:8105988
teensy_size: RAM1: variables:3808, code:6288, padding:26480 free for local variables:487712
teensy_size: RAM2: variables:12416 free for malloc/new:511872
Building .pio\build\teensy41\firmware.hex
========= [SUCCESS] Took 2.59 seconds =========
You’re right, I completely missed the Foo prefix for the definition of doSomething. The odd thing was that intellisense was accepting the foo.soSomething() call and was even pointing to the same declaration when Alt clicking it.
It’s been a long day
As for the library.json, that must have been the issue all along. I’ve now changed it to "srcFilter": "+<*> -<.git/> -<.svn/> -<main.cpp>". Thanks for clarifying this! main.cpp was in another library as a test, but I didn’t want it being included / compiled when used as an external library.
