I’m trying to get the library ‘avr_debugger’ by jdolinay working on my arduino Uno. I can remember (or i hope so), that it has worked for me in the past, so i think it should be fixable.
For more detail, I’m getting this error from the linker, when i try to build/upload the [env:uno_debug] enviroment:
Linking .pio\build\uno_debug\firmware.elf
HardwareSerial0.cpp.o (symbol from plugin): In function `Serial':
(.text+0x0): multiple definition of `__vector_18'
avr8-stub.c.o (symbol from plugin):(.text+0x0): first defined here
*** [.pio\build\uno_debug\firmware.elf] Error 1
================================================================================= [FAILED] Took 13.61 seconds =================================================================================
The whole log (pio run --verbose > compile.log 2>&1 --environment uno_debug) is found here on GitHub (from a later run, the error is from the build command without verbose).
Here is the relevant portions of my PlatformIO.ini:
[platformio]
default_envs = uno
[env]
monitor_filters = send_on_enter
monitor_echo = yes
fastled/FastLED@^3.9.9
z3t0/IRremote@^4.4.1
[env:uno_debug]
board = uno
-D DEBUG_ATMEGA328P
debug_tool = avr-stub
debug_port = COM3
${env.lib_deps}
jdolinay/avr-debugger@^1.5
The whole project is available on GitHub:
theMoonlitWolf/Floating-Island-2
I have tried cleaning, searched for the definition in avr8-stub.cpp (and didn’t find it), and the --undefined flag for the linker and nothing worked.
I would still like to be able to use Serial, so can I (safely) ignore this error somehow?
Does anyone have any idea what could fix this?
Thank you very much,
theMoonlitWolf
