I’m trying to build GNUK project with PlatformIO. The original build system uses make, but I’ve decided to try to port it to PlatformIO. I’ve cloned the repository, checked out origin/STABLE-BRANCH-1-0 and created platformio.ini file. I’ve called configure --vidpid=234b:0000 in the src subfolder of the project using Git Bash command prompt. I mention all these steps so that anyone interested could reproduce the problem.
My platformio.ini file is:
[platformio]
[env]
platform = ststm32
board = bluepill_f103c8
board_build.ldscript = $PROJECT_DIR/src/gnuk.ld
board_dir = $PROJECT_DIR/boards/OLIMEX_STM32_H103a
chibi_os = $PROJECT_DIR/ChibiOS_2.0.8
cryptdir = $PROJECT_DIR/polarssl-0.14.0
cryptsrcdir = ${env.cryptdir}/library
cryptincdir = ${env.cryptdir}/include
src_filter = +<main.c> +<usb_lld.c> +<usb_desc.c> +<usb_ctrl.c> +<usb-icc.c> +<openpgp.c> +<ac.c> +<openpgp-do.c> +<flash.c> +<random.c> +<neug.c> +<sys.c> \
+<${env.board_dir}/board.c>
+<${env.chibi_os}/os/hal/platforms/STM32/*.c> \
+<${env.chibi_os}/os/hal/src/*.c> \
+<${env.chibi_os}/os/ports/GCC/ARMCMx/chcore.c> \
+<${env.chibi_os}/os/ports/GCC/ARMCMx/chcore_v7m.c> \
+<${env.chibi_os}/os/ports/GCC/ARMCMx/nvic.c> \
+<${env.chibi_os}/os/ports/GCC/ARMCMx/cmsis/core_cm3.c> \
+<${env.chibi_os}/os/kernel/src/*.c> \
+<${env.chibi_os}/os/various/evtimer.c> \
+<${env.chibi_os}/os/various/syscalls.c> \
+<${env.cryptsrcdir}/bignum.c> \
+<${env.cryptsrcdir}/rsa.c> \
+<${env.cryptsrcdir}/aes.c> \
build_flags = -DKEYGEN_SUPPORT -I${env.cryptincdir} -I${env.chibi_os}/os/hal/include -I${env.chibi_os}/os/hal/platforms/STM32 -I${env.chibi_os}/os/ports/GCC/ARMCMx -I${env.chibi_os}/os/ports/GCC/ARMCMx/STM32F10x -I${env.chibi_os}/os/ports/GCC/ARMCMx/cmsis -I${env.chibi_os}/os/kernel/include -I$PROJECT_DIR/boards/common -I${env.board_dir} -I${env.chibi_os}/os/various
[env:OLIMEX_STM32_H103]
It’s still incomplete, but still…
The build process aborts on the linking stage:
arm-none-eabi-gcc -o .pio\build\OLIMEX_STM32_H103\firmware.elf -T "C:\Temp\Platformio Projects\gnuk/src/gnuk.ld" -Os -Wl,--gc-sections,--relax -mthumb -mcpu=cortex-m3 .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\hal\platforms\STM32\adc_lld.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\hal\platforms\STM32\can_lld.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\hal\platforms\STM32\hal_lld.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\hal\platforms\STM32\pal_lld.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\hal\platforms\STM32\pwm_lld.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\hal\platforms\STM32\serial_lld.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\hal\platforms\STM32\spi_lld.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\hal\platforms\STM32\stm32_dma.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\hal\src\adc.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\hal\src\can.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\hal\src\hal.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\hal\src\mac.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\hal\src\mmc_spi.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\hal\src\pal.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\hal\src\pwm.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\hal\src\serial.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\hal\src\spi.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\kernel\src\chcond.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\kernel\src\chdebug.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\kernel\src\chevents.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\kernel\src\chheap.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\kernel\src\chlists.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\kernel\src\chmboxes.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\kernel\src\chmemcore.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\kernel\src\chmempools.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\kernel\src\chmsg.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\kernel\src\chmtx.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\kernel\src\chqueues.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\kernel\src\chregistry.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\kernel\src\chschd.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\kernel\src\chsem.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\kernel\src\chsys.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\kernel\src\chthreads.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\kernel\src\chvt.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\ports\GCC\ARMCMx\chcore.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\ports\GCC\ARMCMx\chcore_v7m.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\ports\GCC\ARMCMx\cmsis\core_cm3.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\ports\GCC\ARMCMx\nvic.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\various\evtimer.o .pio\build\OLIMEX_STM32_H103\ChibiOS_2.0.8\os\various\syscalls.o .pio\build\OLIMEX_STM32_H103\boards\OLIMEX_STM32_H103\board.o .pio\build\OLIMEX_STM32_H103\polarssl-0.14.0\library\aes.o .pio\build\OLIMEX_STM32_H103\polarssl-0.14.0\library\bignum.o .pio\build\OLIMEX_STM32_H103\polarssl-0.14.0\library\rsa.o .pio\build\OLIMEX_STM32_H103\src\ac.o .pio\build\OLIMEX_STM32_H103\src\flash.o .pio\build\OLIMEX_STM32_H103\src\main.o .pio\build\OLIMEX_STM32_H103\src\neug.o .pio\build\OLIMEX_STM32_H103\src\openpgp-do.o .pio\build\OLIMEX_STM32_H103\src\openpgp.o .pio\build\OLIMEX_STM32_H103\src\random.o .pio\build\OLIMEX_STM32_H103\src\sys.o .pio\build\OLIMEX_STM32_H103\src\usb-icc.o .pio\build\OLIMEX_STM32_H103\src\usb_ctrl.o .pio\build\OLIMEX_STM32_H103\src\usb_desc.o .pio\build\OLIMEX_STM32_H103\src\usb_lld.o -LC:\.platformio\platforms\ststm32\ldscripts -L.pio\build\OLIMEX_STM32_H103 -Wl,--start-group -lc -lgcc -lm -lstdc++ -Wl,--end-group
c:/.platformio/packages/toolchain-gccarmnoneeabi@1.70201.0/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/bin/ld.exe: cannot find sys.o
*** [.pio\build\OLIMEX_STM32_H103\firmware.elf] Error 1
But sys.o file is specified among the arguments to the linker, and this file is present in the build cache directory (.pio\build\OLIMEX_STM32_H103\src\sys.o). How can I fix the error?
