Hi! I have some trouble with linking my private library to arduino platform.
I have an library for esp32/esp8266 with this library.json:
"name": "libname",
"desciption": "libdesc",
"keywords":"keyword",
"authors": {
"name":"My Name",
"mainteiner":true
"repository": {
"type":"git",
"url":"https://github.com/sobieg/libname.git"
"version":"1.0",
"license":"MIT",
"frameworks": "arduino",
"platforms": "espressif8266, espressif32",
"headers": "mainheader.h"
Inside i have a function, like
#include "Arduino.h"
int randombytes(unsigned char* random_array, unsigned long long nbytes)
randomSeed(analogRead(0));
for (unsigned long long i = 0; i<nbytes; i++) {
random_array[i] = secureRandom(2, 4);
return 0;
I compile library in a project with this platformio.ini:
[env:esp12e]
platform = espressif8266
board = esp12e
board_build.ldscript = eagle.flash.4m1m.ld
libname
lib_extra_dirs =
/full/path/to/dir/with/private/libs/
And get an linker error:
/opt/homebrew/bin/platformio -c clion run --target upload -e esp12e
Obsolete PIO Core v5.2.3 is used (previous was 5.2.4)
Please remove multiple PIO Cores from a system: link
Processing esp12e (platform: espressif8266; board: esp12e; framework: arduino)
CONFIGURATION: link
PLATFORM: Espressif 8266 (3.2.0) > Espressif ESP8266 ESP-12E
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
- framework-arduinoespressif8266 3.30002.0 (3.0.2)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- tool-mklittlefs 1.203.210628 (2.3)
- tool-mkspiffs 1.200.0 (2.0)
- toolchain-xtensa 2.100300.210717 (10.3.0)
LDF: Library Dependency Finder -> link
Found 40 compatible libraries
|-- <libname> 1.0
Compiling .pio/build/esp12e/src/main.cpp.o
Compiling .pio/build/esp12e/lib206/libname/libsource.c.o
Linking .pio/build/esp12e/firmware.elf
/path/to/xtensa-lx106-elf/bin/ld: .pio/build/esp12e/lib206/liblibname.a(libsource.c.o):(.text.randombytes+0x0): undefined reference to `randomSeed'
/path/to/xtensa-lx106-elf/bin/ld: .pio/build/esp12e/lib206/liblibname.a(libsource.c.o):(.text.randombytes+0x4): undefined reference to `secureRandom'
/path/to/xtensa-lx106-elf/bin/ld: .pio/build/esp12e/lib206/liblibname.a(libsource.c.o): in function `randombytes':
libsource.c:(.text.randombytes+0x20): undefined reference to `randomSeed'
/path/to/xtensa-lx106-elf/bin/ld: libsource.c:(.text.randombytes+0x3b): undefined reference to `secureRandom'
*** [.pio/build/esp12e/firmware.elf] Error 1
[FAILED] Took 6.17 seconds
Without adding this functions, library compiles, links and works fine, so what can i do to build my library with arduino functions?
