Ok… I ran zadig yet again (5th time?) and now I have the magic preferred Device Manager screen:
and… I appear to have some form of communications with the device!
I’m still getting a GOB ton of errors:
PLATFORM: Espressif 32 1.11.1 > Espressif ESP32 Dev Module
PACKAGES: toolchain-xtensa32 2.50200.80 (5.2.0), framework-arduinoespressif32 2.10004.191002 (1.0.4), tool-esptoolpy 1.20600.0 (2.6.0)
Found 26 compatible libraries
Building in debug mode
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
DATA: [ ] 4.7% (used 15436 bytes from 327680 bytes)
PROGRAM: [== ] 16.5% (used 216725 bytes from 1310720 bytes)
========================= [SUCCESS] Took 3.79 seconds =========================
Reading symbols from c:\Users\JamesN4\Documents\PlatformIO\Projects\Blink\.pio\build\esp32dev\firmware.elf...
done.
PlatformIO: debug_tool = esp-prog
Open On-Chip Debugger v0.10.0-esp32-20190708 (2019-07-08-11:04)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
Info : Configured 2 cores
esp32 interrupt mask on
Info : tcl server disabled
Info : telnet server disabled
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Error: No symbols for FreeRTOS
Info : Target halted. PRO_CPU: PC=0x40007BA1 (active) APP_CPU: PC=0x400076E0
Info : Target halted. PRO_CPU: PC=0x400916EE (active) APP_CPU: PC=0x400076E0
Info : Flash mapping 0: 0x110010 -> 0x3f400010, 113 KB
Info : Flash mapping 1: 0x150018 -> 0x400d0018, 489 KB
Info : Auto-detected flash size 4194303 KB
Info : Using flash size 4194303 KB
Info : Using flash size 492 KB
Info : Using flash size 116 KB
warning: Overlapping regions in memory map: ignoring
0x40007ba1 in ?? ()
Temporary breakpoint 1 at 0x400d0bf8: file src\main.cpp, line 4.
Info : esp32: Debug controller 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : Target halted. PRO_CPU: PC=0x5000004B (active) APP_CPU: PC=0x00000000
Info : esp32: Core 0 was reset (pwrstat=0x1F, after clear 0x0F).
Info : esp32: Debug controller 1 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 1 was reset (pwrstat=0x5F, after clear 0x0F).
Info : Target halted. PRO_CPU: PC=0x40000400 (active) APP_CPU: PC=0x40000400
** Programming Started **
auto erase enabled
auto erase enabled
Info : Target halted. PRO_CPU: PC=0x400916EE (active) APP_CPU: PC=0x40000400
wrote 16384 bytes from file C:/Users/JamesN4/.platformio/packages/framework-arduinoespressif32/tools/sdk/bin/bootloader_dio_40m.bin in 0.688068s (23.254 KiB/s)
** Programming Finished **
** Verify Started **
read 15872 bytes from file C:/Users/JamesN4/.platformio/packages/framework-arduinoespressif32/tools/sdk/bin/bootloader_dio_40m.bin and flash bank 0 at offset 0x00001000 in 0.328033s (47.251 KiB/s)
contents differ
diff 0 address 0x00001004. Was 0x3c instead of 0xac
diff 1 address 0x00001005. Was 0x81 instead of 0x06
diff 2 address 0x00001006. Was 0x09 instead of 0x08
diff 3 address 0x00001008. Was 0x00 instead of 0xee
diff 4 address 0x00001017. Was 0x00 instead of 0x01
diff 5 address 0x00001018. Was 0x00 instead of 0x18
contents differ
(snip)
diff 126 address 0x000010a4. Was 0x0a instead of 0x69
diff 127 address 0x000010a5. Was 0x00 instead of 0x6c
More than 128 errors, the rest are not printed.
diff 123 address 0x000010a1. Was 0x65 instead of 0x2d
diff 124 address 0x000010a2. Was 0x3a instead of 0x62
diff 125 address 0x000010a3. Was 0x0d instead of 0x75
embedded:startup.tcl:480: Error: ** Verify Failed **
in procedure 'program_esp32'
in procedure 'program_error' called at file "C:/Users/JamesN4/.platformio/packages/tool-openocd-esp32/share/openocd/scripts/target/esp32.cfg", line 138
at file "embedded:startup.tcl", line 480
auto erase enabled
auto erase enabled
wrote 4096 bytes from file c:/Users/JamesN4/Documents/PlatformIO/Projects/Blink/.pio/build/esp32dev/partitions.bin in 0.615062s (6.503 KiB/s)
read 3072 bytes from file c:/Users/JamesN4/Documents/PlatformIO/Projects/Blink/.pio/build/esp32dev/partitions.bin and flash bank 0 at offset 0x00008000 in 0.285029s (10.525 KiB/s)
contents differ
diff 0 address 0x00008003. Was 0x01 instead of 0x02
diff 1 address 0x00008005. Was 0xf0 instead of 0x90
diff 2 address 0x00008009. Was 0x10 instead of 0x50
diff 3 address 0x0000800c. Was 0x70 instead of 0x6e
diff 4 address 0x0000800d. Was 0x68 instead of 0x76
diff 5 address 0x0000800e. Was 0x79 instead of 0x73
contents differ
(snip)
diff 74 address 0x000080bb. Was 0x00 instead of 0x5d
diff 78 address 0x000080bf. Was 0x00 instead of 0x07
diff 75 address 0x000080bc. Was 0x00 instead of 0xb9
diff 76 address 0x000080bd. Was 0x00 instead of 0x7a
diff 77 address 0x000080be. Was 0x00 instead of 0x25
auto erase enabled
auto erase enabled
wrote 8192 bytes from file C:/Users/JamesN4/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin in 0.638064s (12.538 KiB/s)
read 8192 bytes from file C:/Users/JamesN4/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin and flash bank 0 at offset 0x0000e000 in 0.311031s (25.721 KiB/s)
contents differ
diff 0 address 0x0000e000. Was 0xff instead of 0x01
diff 1 address 0x0000e001. Was 0xff instead of 0x00
diff 2 address 0x0000e002. Was 0xff instead of 0x00
diff 3 address 0x0000e003. Was 0xff instead of 0x00
diff 4 address 0x0000e01c. Was 0xff instead of 0x9a
(snip)
diff 127 address 0x0000f077. Was 0x00 instead of 0xff
diff 123 address 0x0000f073. Was 0x00 instead of 0xff
diff 124 address 0x0000f074. Was 0x00 instead of 0xff
diff 125 address 0x0000f075. Was 0x00 instead of 0xff
diff 126 address 0x0000f076. Was 0x00 instead of 0xff
auto erase enabled
auto erase enabled
wrote 217088 bytes from file c:/Users/JamesN4/Documents/PlatformIO/Projects/Blink/.pio/build/esp32dev/firmware.bin in 1.347135s (157.371 KiB/s)
read 216848 bytes from file c:/Users/JamesN4/Documents/PlatformIO/Projects/Blink/.pio/build/esp32dev/firmware.bin and flash bank 0 at offset 0x00010000 in 1.127112s (187.883 KiB/s)
contents differ
diff 0 address 0x00010001. Was 0x07 instead of 0x06
diff 1 address 0x00010004. Was 0xac instead of 0x70
diff 2 address 0x00010005. Was 0x07 instead of 0x19
diff 3 address 0x00010008. Was 0x00 instead of 0xee
diff 4 address 0x00010017. Was 0x00 instead of 0x01
diff 5 address 0x00010018. Was 0x00 instead of 0x20
contents differ
(snip)
diff 127 address 0x000100c0. Was 0x00 instead of 0x48
diff 123 address 0x000100a2. Was 0x00 instead of 0xff
diff 124 address 0x000100b4. Was 0x00 instead of 0x48
diff 125 address 0x000100b8. Was 0x00 instead of 0x48
diff 126 address 0x000100bc. Was 0x00 instead of 0x48
PlatformIO: Resume the execution to `debug_init_break = tbreak setup`
PlatformIO: More configuration options -> http://bit.ly/pio-debug
Error: esp32: Failed to read insn (-4)!
Error: esp32: Failed to add SW BP!
Error: can't add breakpoint: resource not available
Warning:
Cannot insert breakpoint 1.
Cannot access memory at address 0x400d0bf8
