Hi @ivankravets,
LibreTiny has a version 1.3.0 published via GitHub actions a week ago but it has not been approved and not available in the registry.
Is there an issue with the package?
Kind Regards,
Jesse
ESPHome Developer @ Nabu Casa
Hi @ivankravets,
Kind Regards,
Jesse
There is a security issue with LibreTiny dev-platform. It breaks PlatformIO’s Python virtual environment in runtime. You make a lot of hacks before the platform is initialized. I recommend moving ltchiptool
source code to the final release of dev-platform and using site module:
import site
site.addsitedir(os.path.join(os.path.dirname(os.path.realpath(__file__)), "ltchiptool"))
import ltchiptool
Shortly, the LibretinyPlatform()
constructor and whole module should not corrupt any environment.
I have addressed the issue now, I think. The fix is currently in another branch, because it needs proper testing.
I did it the same way as ESP32 platform does, which is creating another virtual environment in the penv
directory under .platformio
. This way LibreTiny doesn’t install ltchiptool
to the global environment.
The platform.py
file has been modified not to require ltchiptool
at all, instead it bundles a part of its source code in tools
directory.
I hope this will resolve the security issue.
Regards,
Kuba
