Hi, I’m working on a pretty big arduino project with a wemos d1 mini.
I need almost all the pins but pin 15 isn’t working as output with the newest version from esp8266 audio. I also can’t change the version to 1.7 where it’s said to work because platformio complains that theres no compatible version for windows amd64.
So I tried to manually download the library Esp8266audio version 1.7.0 and put it in the ./lib folder. When I compile the project I get the error
lib\ESP8266Audio-1.7.0\src\AudioFileSourceICYStream.h:28:12: fatal error: ESP8266HTTPClient.h: No such file or directory
Is there something I have to add to the platform.ini? Thansk for yor help.`
Full platformio.ini? Did you try adding lib_ldf_mode = deep+?
Oh here it is `
; Redirecting...
[env:d1_mini]
platform = espressif8266
board = d1_mini
board_build.f_cpu = 160000000L
upload_speed=921600
olikraus/U8g2@^2.35.7
arkhipenko/TaskScheduler@^3.7.0
adafruit/Adafruit NeoPixel@^1.11.0
painlessmesh/painlessMesh@^1.5.0
crankyoldgit/IRremoteESP8266@^2.8.6`
Ok, tried it, works.
Thanks for your quick help.
