Hi!
I’m creating a library using platformio, and I want it:
- to be arduino compatible
- to have unit tests you can actually build and run
- to have examples you also can build and run
So far, here is what I came up with. My source are organized this way:
├── README.md
├── examples
│ └── Simple
│ └── Simple.cpp
├── include
├── library.json
├── library.properties
├── platformio.ini
├── src
│ ├── nmeaparser.cpp
│ └── nmeaparser.h
└── test
└── tests.cpp
My platformio.ini file is the following:
[platformio]
#lib_dir = .
#src_dir = examples/Simple
include_dir = src
[env:arduinomega2560]
board = megaatmega2560
test_build_project_src = yes
upload_speed = 3000000
If I want to run unit tests, [platformio] section is the one above. If I want to build the example, I must switch commented lines to this:
[platformio]
lib_dir = .
#include_dir = src
Is there a better way to have both?
