I worked on a project for the last time on August 20th. Today I wanted to start work again, but without a change it doesn’t build anymore. Currently I’m on Core 4.1.0b1
> Executing task: platformio run --environment esp12e <
Processing esp12e (platform: espressif8266; board: esp12e; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp12e.html
PLATFORM: Espressif 8266 2.2.3 > Espressif ESP8266 ESP-12E
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
PACKAGES: toolchain-xtensa 2.40802.190218 (4.8.2), tool-esptool 1.413.0 (4.13), tool-esptoolpy 1.20600.0 (2.6.0), framework-arduinoespressif8266 2.20502.0 (2.5.2)
LibraryManager: Installing id=727 @ ~3.0.1
UndefinedPackageVersion: Could not find a version that satisfies the requirement '~3.0.1' for your system 'linux_x86_64':
File "/home/flurl/.platformio/penv/local/lib/python2.7/site-packages/platformio/builder/main.py", line 145:
File "/home/flurl/.platformio/packages/tool-scons/script/../engine/SCons/Script/SConscript.py", line 541:
File "/home/flurl/.platformio/packages/tool-scons/script/../engine/SCons/Script/SConscript.py", line 250:
exec _file_ in call_stack[-1].globals
File "/home/flurl/.platformio/platforms/espressif8266/builder/main.py", line 203:
File "/home/flurl/.platformio/packages/tool-scons/script/../engine/SCons/Environment.py", line 224:
File "/home/flurl/.platformio/penv/local/lib/python2.7/site-packages/platformio/builder/tools/platformio.py", line 129:
_build_project_deps(env)
File "/home/flurl/.platformio/penv/local/lib/python2.7/site-packages/platformio/builder/tools/platformio.py", line 47:
project_lib_builder = env.ConfigureProjectLibBuilder()
File "/home/flurl/.platformio/penv/local/lib/python2.7/site-packages/platformio/builder/tools/piolib.py", line 1070:
project.install_dependencies()
File "/home/flurl/.platformio/penv/local/lib/python2.7/site-packages/platformio/builder/tools/piolib.py", line 901:
lm.install(uri)
File "/home/flurl/.platformio/penv/local/lib/python2.7/site-packages/platformio/managers/lib.py", line 368:
force=force,
File "/home/flurl/.platformio/penv/local/lib/python2.7/site-packages/platformio/managers/package.py", line 700:
pkg_dir = self._install_from_piorepo(name, requirements)
File "/home/flurl/.platformio/penv/local/lib/python2.7/site-packages/platformio/managers/lib.py", line 207:
requirements or "latest", util.get_systype()
============================================================================= [FAILED] Took 0.35 seconds =============================================================================
Environment Status Duration
esp12e FAILED 00:00:00.351
nodemcuv2 IGNORED
======================================================================= 1 failed, 0 succeeded in 00:00:00.351 =======================================================================
My platformio.ini:
[common]
lib_deps_external =
# ArduinoJson
64
#@~5.13.4
# ESPAsyncTCP
305@~1.2.0
# ESP Async WebServer
306@~1.2.2
# flurl's FSBrowserNG
https://github.com/flurl/FSBrowserNG.git
# NtpClientLib
727@~3.0.1
# Time
44@1.5
# ===Project dependencies===
# Servo
# 883@~1.1.4
[env:esp12e]
platform = espressif8266
board = esp12e
${common.lib_deps_external}
[env:nodemcuv2]
board = nodemcuv2
Obviously the library manager fails to find a suitable version for id 727 (NtpClientLib). According to PlatformIO Registry the latest version is labled 3.0.1-beta
and indeed changing the version string in platformio.ini to 727@~3.0.1-beta
solves the issue.
My question is now, what is the intended behaviour? Was it broken before, when it accepted the version without the “-beta” suffix or is it broken now and should I report a bug?
I’d have downgraded PIO to find the release causing that behavioural change, but couldn’t figure out how to downgrade.
Beside that, could someone explain, why the error message reads
Shouldn’t it be looking for a version for the platform and/or the framework?
