Against better judgement, we had to rename our “Sensirion I2C SVM41” library to “Sensirion I2C SVM4x”. It is published via the Arduino library registry and used to show up in the Platformio registry as well, however neither the old nor the new version show up on the latter since the name change (pio lib install fails as well). The url of the updated library, which also changed, is GitHub - Sensirion/arduino-i2c-svm4x: Arduino library to work with the Sensirion's SVM41 sensor modules via I2C. Are there additional steps we need to take? Thank you for your help!
CC @ivankravets for help
Done! See
Lightning speed as always. And it’s immediately available for installation, perfect! Thanks so much:)
