Does the library manager support prerelease versioning and releases? If so I cannot get it to work with semver, any exmaples or tips, I did not see any specific mention in docs.
Arduino does support and pick these up
I’ve observed with LVGL which released a “8.0.0-dev” version as the semver that it would not install per lvgl installation recommendation does not work · Issue #3960 · platformio/platformio-core · GitHub.
If I remember correctly, @ivankravets said in a github issue that I can’t find anymore that one should not push pre-release versions into the library registry, only stables. For pre-releases, one can use lib_deps to explicitly point to the github repository / certain branch.
Maybe he has more thoughts on this.
Thanks, Just found that
Yes, you can publish pre-release versions to the registry. We had a problem with an incorrect installation guide on https://platformio.org/lib. Now, we generate valid SemVer specification.
How do pre-releases work wrt. unreleased dependencies?
SignalK/SensESP is currently at version 1.0.8. We’re working heavily on 2.0.0. Part of that release is splitting some code into separate add-on libraries that depend on SignalK/SensESP@^2.0.0. I have created the add-on library repos but can’t test them in real life until SensESP 2.0.0 has been released.
If I now release SignalK/SensESP 2.0.0-alpha.1:
lib_deps = SignalK/SensESP? Do they pull 1.0.8 or 2.0.0-alpha.1?lib_deps = SignalK/SensESP @ ^2.0.0? Does that pull 2.0.0-alpha.1?You can test this with Python REPL (run python in PlatformIO CLI console) using GitHub - rbarrois/python-semanticversion: Semantic version comparison for Python (see http://semver.org/)
>>> import semantic_version
>>> semantic_version.SimpleSpec("^2.0.0").match(semantic_version.Version("2.0.0-alpha.1"))
False
Thanks, that’s handy!
A little experimentation indicates that prereleases are to be avoided at all costs:
In [26]: SimpleSpec("<2.0.0").match(Version("2.0.0-alpha.2"))
Out[26]: False
In [27]: SimpleSpec("<=2.0.0").match(Version("2.0.0-alpha.2"))
Out[27]: True
In [28]: SimpleSpec("=2.0.0").match(Version("2.0.0-alpha.2"))
Out[28]: False
In [29]: SimpleSpec("^2.0.0").match(Version("2.0.0-alpha.2"))
Out[29]: False
In [30]: SimpleSpec("^2.0.0-alpha").match(Version("2.0.0-alpha.2"))
Out[30]: False
In [31]: SimpleSpec("^2.0.0-alpha.1").match(Version("2.0.0-alpha.2"))
Out[31]: False
In [32]: SimpleSpec("^2.0.0-alpha.2").match(Version("2.0.0-alpha.2"))
Out[32]: False
I think that is correct. 2.0.0-alpha is less than 2.0.0 (which means stable release). What do you think?
I’m also looking to install a pre release version library (tzapu/WiFiManager also).
I tried to add in my platformio.ini project file
tzapu/WiFiManager@2.0.16-rc.2
Unfortunately I’m getting the following error message
Resolving esp32dev dependencies...
Library Manager: Installing tzapu/WiFiManager @ ^2.0.16-rc.2
Error: Could not find the package with 'tzapu/WiFiManager @ ^2.0.16-rc.2' requirements for your system 'windows_amd64'
Any idea how I can pass a RC version number ?
Using platformio.ini with
https://github.com/tzapu/WiFiManager/
I’m getting
Removing unused dependencies...
Library Manager: Installing git+https://github.com/tzapu/WiFiManager/
git version 2.41.0.windows.1
Cloning into 'C:\Users\scelles\.platformio\.cache\tmp\pkg-installing-mtrqrrth'...
Library Manager: WiFiManager@2.0.16-rc.2+sha.3a303ee has been installed!
Updating metadata for the vscode IDE...
Project has been successfully updated!
But I would prefer to stick with a fixed version number in platformio.ini so I also tried
but building raises
--------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
PLATFORM: Espressif 32 (6.3.1) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 @ 3.20009.0 (2.0.9)
Library Manager: Installing WiFiManager @ 2.0.16-rc.2+sha.3a303ee
Warning! Could not find the package with 'WiFiManager @ 2.0.16-rc.2+sha.3a303ee' requirements for your system
'windows_amd64'
Found 35 compatible libraries
|-- DHT sensor library @ 1.4.4
|-- Adafruit Unified Sensor @ 1.1.9
Compiling .pio\build\esp32dev\src\main.cpp.o
Building .pio\build\esp32dev\bootloader.bin
Generating partitions .pio\build\esp32dev\partitions.bin
esptool.py v4.5.1
Creating esp32 image...
Merged 1 ELF section
Compiling .pio\build\esp32dev\lib9b3\Adafruit Unified Sensor\Adafruit_Sensor.cpp.o
Compiling .pio\build\esp32dev\libf6d\DHT sensor library\DHT.cpp.o
Compiling .pio\build\esp32dev\libf6d\DHT sensor library\DHT_U.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\FirmwareMSC.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\HWCDC.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\IPAddress.cpp.o
src/main.cpp:2:10: fatal error: WiFiManager.h: No such file or directory
* Looking for WiFiManager.h dependency? Check our library registry!
* CLI > platformio lib search "header:WiFiManager.h"
* Web > https://registry.platformio.org/search?q=header:WiFiManager.h
#include <WiFiManager.h>
compilation terminated.
*** [.pio\build\esp32dev\src\main.cpp.o] Error 1
======================================== [FAILED] Took 10.03 seconds ========================================
* The terminal process "C:\Users\scelles\.platformio\penv\Scripts\platformio.exe 'run', '--environment', 'esp32dev'" terminated with exit code: 1.
Any idea what is wrong?
Thanks
For stable versions from the registry, you can only pass those that are registered. See PlatformIO Registry.
Per Tags · tzapu/WiFiManager · GitHub there are stable tags. So just say
https://github.com/tzapu/WiFiManager.git#v2.0.16-rc.2
like the documentation already says.
