I can’t seem to get this to work for me. I can see the defines in the global environment with print global_env.Dump()
but run -v shows that those flags are not being used to build the libraries.
My library.json is here: ModularSensors/library.json at develop · EnviroDIY/ModularSensors · GitHub
"build":
"srcFilter":
"+<*.c>",
"+<*.cpp>",
"+<*.h>",
"+<sensors/*.c>",
"+<sensors/*.cpp>",
"+<sensors/*.h>"
"extraScript": "pioScripts/pio_set_global_flags.py",
"libLDFMode": "deep+"
then the extra script (pio_set_global_flags.py): ModularSensors/pio_set_global_flags.py at develop · EnviroDIY/ModularSensors · GitHub
Import('env')
from os.path import join, realpath
# append flags to local build environment (for just this library)
env.Append(
CPPDEFINES=[
("NEOSWSERIAL_EXTERNAL_PCINT",),
("SDI12_EXTERNAL_PCINT",)
print ">>>>>LOCAL ENV<<<<<"
print env.Dump()
# append the same flags to the global build environment (for all libraries, etc)
global_env = DefaultEnvironment()
global_env.Append(
CPPDEFINES=[
print "<<<<<GLOBAL ENV>>>>>"
And just some of the relevant chunks of the verbose output:
>>>>>LOCAL ENV<<<<<
'CPPDEFINES': [ ('PLATFORMIO', 30602),
('ARDUINO_AVR_ENVIRODIY_MAYFLY',),
('F_CPU', '$BOARD_F_CPU'),
('ARDUINO_ARCH_AVR',),
('ARDUINO', 10805),
('NEOSWSERIAL_EXTERNAL_PCINT',),
('SDI12_EXTERNAL_PCINT',)],
('ARDUINO', 10805),
Collected 44 compatible libraries
|-- <EnviroDIY_ModularSensors> 0.17.1 #1b2407d [git+https://github.com/EnviroDIY/ModularSensors#develop] (xx_myFolder_xx\.piolibdeps\EnviroDIY_ModularSensors)
| |-- <Arduino-SDI-12> 1.3.4 (xx_myFolder_xx\.piolibdeps\Arduino-SDI-12_ID1486)
avr-g++ -o .pioenvs\mayfly\src\main.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=atmega1284p -DPLATFORMIO=30602 -DARDUINO_AVR_ENVIRODIY_MAYFLY -DF_CPU=8000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -DNEOSWSERIAL_EXTERNAL_PCINT -DSDI12_EXTERNAL_PCINT -I.piolibdeps\SoftwareSerial_ExtInts\src -I.piolibdeps\AltSoftSerial -I.piolibdeps\EnviroDIY_ModularSensors\src -I.piolibdeps\YosemitechModbus_ID2078\src -I.piolibdeps\TinyGSM\src -I.piolibdeps\MS5803_ID5431\src -I.piolibdeps\Arduino-SDI-12_ID1486\src -I.piolibdeps\DallasTemperature_ID54 -I.piolibdeps\OneWire_ID1 "-I.piolibdeps\Adafruit MPL115A2_ID406" "-I.piolibdeps\DHT sensor library_ID19" "-I.piolibdeps\Adafruit BME280 Library_ID166" "-I.piolibdeps\Adafruit AM2315_ID773" "-I.piolibdeps\Adafruit Unified Sensor_ID31" -I.piolibdeps\ADS1X15_ID344 -I.piolibdeps\SdFat_ID322\src -IC:\Users\sdamiano.STROUDWATER\.platformio\packages\framework-arduinoavr\libraries\__cores__\arduino\SPI\src -I.piolibdeps\EnableInterrupt_ID311 -I.piolibdeps\EnableInterrupt_ID311\utility -I.piolibdeps\EnviroDIY_DS3231_ID2079\src -IC:\Users\sdamiano.STROUDWATER\.platformio\packages\framework-arduinoavr\libraries\__cores__\arduino\Wire\src -I.piolibdeps\KellerModbus\src -I.piolibdeps\SensorModbusMaster_ID1824\src -Isrc -Iinclude -IC:\Users\sdamiano.STROUDWATER\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\sdamiano.STROUDWATER\.platformio\packages\framework-arduinoavr\variants\mayfly src\main.cpp
avr-g++ -o .pioenvs\mayfly\lib289\Arduino-SDI-12_ID1486\SDI12.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=atmega1284p -DPLATFORMIO=30602 -DARDUINO_AVR_ENVIRODIY_MAYFLY -DF_CPU=8000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -I.piolibdeps\Arduino-SDI-12_ID1486\src -IC:\Users\sdamiano.STROUDWATER\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\sdamiano.STROUDWATER\.platformio\packages\framework-arduinoavr\variants\mayfly .piolibdeps\Arduino-SDI-12_ID1486\src\SDI12.cpp
avr-g++ -o .pioenvs\mayfly\lib289\Arduino-SDI-12_ID1486\SDI12_boards.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=atmega1284p -DPLATFORMIO=30602 -DARDUINO_AVR_ENVIRODIY_MAYFLY -DF_CPU=8000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -I.piolibdeps\Arduino-SDI-12_ID1486\src -IC:\Users\sdamiano.STROUDWATER\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\sdamiano.STROUDWATER\.platformio\packages\framework-arduinoavr\variants\mayfly .piolibdeps\Arduino-SDI-12_ID1486\src\SDI12_boards.cpp
avr-gcc-ar rc .pioenvs\mayfly\lib289\libArduino-SDI-12_ID1486.a .pioenvs\mayfly\lib289\Arduino-SDI-12_ID1486\SDI12.cpp.o .pioenvs\mayfly\lib289\Arduino-SDI-12_ID1486\SDI12_boards.cpp.o
avr-g++ -o .pioenvs\mayfly\libe71\EnviroDIY_ModularSensors\sensors\SDI12Sensors.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=atmega1284p -DPLATFORMIO=30602 -DARDUINO_AVR_ENVIRODIY_MAYFLY -DF_CPU=8000000L -DARDUINO_ARCH_AVR -DARDUINO=10805 -DNEOSWSERIAL_EXTERNAL_PCINT -DSDI12_EXTERNAL_PCINT -I.piolibdeps\EnviroDIY_ModularSensors\src -I.piolibdeps\YosemitechModbus_ID2078\src -I.piolibdeps\TinyGSM\src -I.piolibdeps\MS5803_ID5431\src -I.piolibdeps\KellerModbus\src -I.piolibdeps\SensorModbusMaster_ID1824\src -I.piolibdeps\Arduino-SDI-12_ID1486\src -I.piolibdeps\DallasTemperature_ID54 -I.piolibdeps\OneWire_ID1 "-I.piolibdeps\Adafruit MPL115A2_ID406" "-I.piolibdeps\DHT sensor library_ID19" "-I.piolibdeps\Adafruit BME280 Library_ID166" "-I.piolibdeps\Adafruit AM2315_ID773" "-I.piolibdeps\Adafruit Unified Sensor_ID31" -I.piolibdeps\ADS1X15_ID344 -I.piolibdeps\SdFat_ID322\src -IC:\Users\sdamiano.STROUDWATER\.platformio\packages\framework-arduinoavr\libraries\__cores__\arduino\SPI\src -I.piolibdeps\EnableInterrupt_ID311 -I.piolibdeps\EnableInterrupt_ID311\utility -I.piolibdeps\EnviroDIY_DS3231_ID2079\src -IC:\Users\sdamiano.STROUDWATER\.platformio\packages\framework-arduinoavr\libraries\__cores__\arduino\Wire\src -IC:\Users\sdamiano.STROUDWATER\.platformio\packages\framework-arduinoavr\cores\arduino -IC:\Users\sdamiano.STROUDWATER\.platformio\packages\framework-arduinoavr\variants\mayfly .piolibdeps\EnviroDIY_ModularSensors\src\sensors\SDI12Sensors.cpp
avr-g++ -o .pioenvs\mayfly\firmware.elf -Os -mmcu=atmega1284p -Wl,--gc-sections -flto -fuse-linker-plugin .pioenvs\mayfly\src\main.cpp.o -L.pioenvs\mayfly -Wl,--start-group .pioenvs\mayfly\lib0ea\libSensorModbusMaster_ID1824.a .pioenvs\mayfly\libab8\libKellerModbus.a .pioenvs\mayfly\lib46b\libWire.a .pioenvs\mayfly\lib2cc\libEnviroDIY_DS3231_ID2079.a .pioenvs\mayfly\lib078\libEnableInterrupt_ID311.a .pioenvs\mayfly\lib2ec\libSPI.a .pioenvs\mayfly\lib9bd\libSdFat_ID322.a .pioenvs\mayfly\lib03e\libADS1X15_ID344.a ".pioenvs\mayfly\lib587\libAdafruit Unified Sensor_ID31.a" ".pioenvs\mayfly\lib287\libAdafruit AM2315_ID773.a" ".pioenvs\mayfly\lib573\libAdafruit BME280 Library_ID166.a" ".pioenvs\mayfly\lib998\libDHT sensor library_ID19.a" ".pioenvs\mayfly\lib609\libAdafruit MPL115A2_ID406.a" .pioenvs\mayfly\libd7f\libOneWire_ID1.a .pioenvs\mayfly\libc2a\libDallasTemperature_ID54.a .pioenvs\mayfly\lib289\libArduino-SDI-12_ID1486.a .pioenvs\mayfly\lib2fb\libMS5803_ID5431.a .pioenvs\mayfly\libfe5\libTinyGSM.a .pioenvs\mayfly\lib37a\libYosemitechModbus_ID2078.a .pioenvs\mayfly\libe71\libEnviroDIY_ModularSensors.a .pioenvs\mayfly\lib843\libAltSoftSerial.a .pioenvs\mayfly\lib065\libSoftwareSerial_ExtInts.a .pioenvs\mayfly\libFrameworkArduinoVariant.a .pioenvs\mayfly\libFrameworkArduino.a -lm -Wl,--end-group
