I searched for library SSD1306_minimal under Libraries but it wasn’t in the Registry do I had to download it. I downloaded from Github, unzipped it and put the files in folder Document/PlatformIO/Projects/<project_name>/.pio/libdeps/digispark-tiny/SSD1306_minimal and added a line in platformio.ini: “lib_deps = kirknorthrop/SSD1306_minimal@^1.0.0”. I still have squiggly lines under #include <SSD1306_minimal> so what’s missing?
I tried to build to see what other errors would crop up and there is a JSONDecodeError which I have no clue what to do with.
Sketch:
// Script and wiring found here....
// https://ebtenorio.wordpress.com/2017/08/03/oled-i2c-with-attiny85/
ATTiny P2-> oLed SCL
ATTiny P0-> oLed SDA
ATTiny GND-> oLed GND
ATTiny 5V-> oLed VCC
#include <SSD1306_minimal.h>
#include <avr/pgmspace.h>
#include <TinyWireM.h>
#include <USI_TWI_Master.h>
#define DEG "xa7" "C"
SSD1306_Mini oled; // Declare the OLED object
void splash() {
oled.startScreen();
oled.clear(); // Clears the display
oled.cursorTo(0, 0); // x:0, y:0
oled.printString(" DuinoKit Fun");
oled.cursorTo(0, 10); // x:0, y:23
oled.printString("With the ATTiny85!");
//oled.cursorTo(0, 20); // x:0, y:46
//oled.printString(" DuinoKit Tiny!");
oled.cursorTo(0, 21); // x:0, y:69
oled.printString(" Coming Soon");
oled.cursorTo(0,31 ); // x:0, y:69
oled.printString("with YOUR support!");
oled.init(0x3C); // Initializes the display to the specified address
delay(1000); // Delay for 1 second
splash(); // Write something to the display (refer to the splash() method
Build output:
> Executing task in folder ATTiny85_OLED: C:\Users\hans\.platformio\penv\Scripts\platformio.exe run <
Processing digispark-tiny (platform: atmelavr; board: digispark-tiny; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/digispark-tiny.html
PLATFORM: Atmel AVR (3.3.0) > Digispark USB
HARDWARE: ATTINY85 16MHz, 512B RAM, 5.87KB Flash
- framework-arduino-avr-digistump 1.7.2
JSONDecodeError: Expecting ',' delimiter: line 1 column 109 (char 108):
File "C:\Users\hans\.platformio\penv\Lib\site-packages\platformio\builder\main.py", line 178:
File "C:\Users\hans\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Script\SConscript.py", line 591:
File "C:\Users\hans\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Script\SConscript.py", line 280:
File "C:\Users\hans\.platformio\platforms\atmelavr\builder\main.py", line 162:
File "C:\Users\hans\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Util.py", line 658:
File "C:\Users\hans\.platformio\penv\Lib\site-packages\platformio\builder\tools\platformio.py", line 62:
env.ProcessProjectDeps()
File "C:\Users\hans\.platformio\penv\Lib\site-packages\platformio\builder\tools\platformio.py", line 141:
project_lib_builder = env.ConfigureProjectLibBuilder()
File "C:\Users\hans\.platformio\penv\Lib\site-packages\platformio\builder\tools\piolib.py", line 1062:
project.install_dependencies()
File "C:\Users\hans\.platformio\penv\Lib\site-packages\platformio\builder\tools\piolib.py", line 886:
if lm.get_package(spec):
File "c:\users\hans\.platformio\penv\lib\site-packages\platformio\package\manager\base.py", line 236:
for pkg in self.get_installed():
File "c:\users\hans\.platformio\penv\lib\site-packages\platformio\package\manager\base.py", line 209:
pkg = PackageItem(pkg_dir)
File "c:\users\hans\.platformio\penv\lib\site-packages\platformio\package\meta.py", line 405:
self.metadata = self.load_meta()
File "c:\users\hans\.platformio\penv\lib\site-packages\platformio\package\meta.py", line 440:
return PackageMetaData.load(manifest_path)
File "c:\users\hans\.platformio\penv\lib\site-packages\platformio\package\meta.py", line 391:
data = json.load(fp)
File "C:\Users\hans\.platformio\python3\lib\json\__init__.py", line 293:
return loads(fp.read(),
File "C:\Users\hans\.platformio\python3\lib\json\__init__.py", line 346:
return _default_decoder.decode(s)
File "C:\Users\hans\.platformio\python3\lib\json\decoder.py", line 337:
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "C:\Users\hans\.platformio\python3\lib\json\decoder.py", line 353:
obj, end = self.scan_once(s, idx)
====================================================== [FAILED] Took 4.64 seconds ======================================================
Platformio.ini:
[env:digispark-tiny]
board = digispark-tiny
