PlatformIO wants to have all the libraries, right? Sounds like it.
Why wouldn’t you have a utility for people to submit libraries for inclusion?
I saw the command prompt text, but it didn’t work. Couldn’t find the file specified, so I guess I don’t have the right application.
These are the errors:
Found 197 compatible libraries
|-- <CurieBLE> 2.0
Compiling .pio\build\esp32doit-devkit-v1\src\main.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libe3f\CurieBLE\BLECentral.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libe3f\CurieBLE\BLECharacteristic.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libe3f\CurieBLE\BLEDescriptor.cpp.o
In file included from c:\users\joema\documents\libraries\curieble\src\internal\bleattribute.h:23:0,
from C:\Users\joema\Documents\libraries\CurieBLE\src\BLEDescriptor.cpp:21:
C:\Users\joema\Documents\libraries\CurieBLE\src/BLECommon.h:26:54: fatal error: ../src/services/ble_servi
compilation terminated.
In file included from C:\Users\joema\Documents\libraries\CurieBLE\src\CurieBLE.h:33:0,
from C:\Users\joema\Documents\libraries\CurieBLE\src\BLECentral.cpp:20:
C:\Users\joema\Documents\libraries\CurieBLE\src\BLECommon.h:26:54: fatal error: ../src/services/ble_servi
In file included from C:\Users\joema\Documents\libraries\CurieBLE\src/CurieBLE.h:33:0,
from src\main.cpp:18:
from C:\Users\joema\Documents\libraries\CurieBLE\src\BLECharacteristic.cpp:22:
*** [.pio\build\esp32doit-devkit-v1\libe3f\CurieBLE\BLEDescriptor.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\libe3f\CurieBLE\BLECentral.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\libe3f\CurieBLE\BLECharacteristic.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\src\main.cpp.o] Error 1
This is the library, in the lib folder:
This is the .ini file, and the library is also in my libraries directory.
How can I make this chronic problem of adding libraries go away? Does having the library in the /lib folder do anything to the same library in the /libraries folder? I’m failing to do something.
Copyright (c) 2016 Intel Corporation. All rights reserved.
See the bottom of this file for the license terms.
* Sketch: BatteryMonitor.ino
* Description:
* This sketch example partially implements the standard Bluetooth
* Low-Energy Battery service and connection interval paramater update.
* For more information:
* https://developer.bluetooth.org/gatt/services/Pages/ServicesHome.aspx
#include <CurieBLE.h>
BLEService batteryService("180F"); // BLE Battery Service
// BLE Battery Level Characteristic"
BLEUnsignedCharCharacteristic batteryLevelChar("2A19", // standard 16-bit characteristic UUID
BLERead | BLENotify); // remote clients will be able to
// get notifications if this characteristic changes
int oldBatteryLevel = 0; // last battery level reading from analog input
long previousMillis = 0; // last time the battery level was checked, in ms
Serial.begin(9600); // initialize serial communication
pinMode(13, OUTPUT); // initialize the LED on pin 13 to indicate when a central is connected
// begin initialization
BLE.begin();
/* Set a local name for the BLE device
This name will appear in advertising packets
and can be used by remote devices to identify this BLE device
The name can be changed but maybe be truncated based on space left in advertisement packet
BLE.setLocalName("BatteryMonitor");
BLE.setAdvertisedService(batteryService); // add the service UUID
batteryService.addCharacteristic(batteryLevelChar); // add the battery level characteristic
BLE.addService(batteryService); // Add the BLE Battery service
batteryLevelChar.setValue(oldBatteryLevel); // initial value for this characteristic
/* Start advertising BLE. It will start continuously transmitting BLE
advertising packets and will be visible to remote BLE central devices
until it receives a new connection */
// start advertising
BLE.advertise();
Serial.println("Bluetooth device active, waiting for connections...");
// listen for BLE peripherals to connect:
BLEDevice central = BLE.central();
// if a central is connected to peripheral:
if (central) {
Serial.print("Connected to central: ");
// print the central's MAC address:
Serial.println(central.address());
// turn on the LED to indicate the connection:
digitalWrite(13, HIGH);
// check the battery level every 200ms
// as long as the central is still connected:
while (central.connected()) {
long currentMillis = millis();
// if 200ms have passed, check the battery level:
if (currentMillis - previousMillis >= 200) {
previousMillis = currentMillis;
updateBatteryLevel();
// when the central disconnects, turn off the LED:
digitalWrite(13, LOW);
Serial.print("Disconnected from central: ");
void updateBatteryLevel() {
/* Read the current voltage level on the A0 analog input pin.
This is used here to simulate the charge level of a battery.
int battery = analogRead(A0);
int batteryLevel = map(battery, 0, 1023, 0, 100);
if (batteryLevel != oldBatteryLevel) { // if the battery level has changed
Serial.print("Battery Level % is now: "); // print it
Serial.println(batteryLevel);
batteryLevelChar.setValue(batteryLevel); // and update the battery level characteristic
oldBatteryLevel = batteryLevel; // save the level for next comparison
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
