I am an absolute noob about c++ and Platformio projects. I am trying to run an example of Adafruit TinyUSB library. What I understand is that compiler should see definitions in platform libs (Espressif ESP32-s2) for TinyUSB for in Adafruit TinyUSB lib. Eg. identifier CFG_TUD_HID is defined in tools/sdk/esp32s2/include/arduino_tinyusb/include/tusb_config.h:104. This identifier is used inside Adafruit lib, but the compiler return an error because the definition of classes and types are hidden under #ifdef CFG_TUD_HID clause.
At the beginning I have
#include "Arduino.h"
#include "Adafruit_TinyUSB.h"
Arduino.h (espressif implementation) should contain identifiers definitions for Adafruit_TinyUSB.h, or am I wrong?
So where is problem? I am using lastest Platformio with settings for Lolin S2 Mini (ESP32-s2 board). It is in settings of compier, setting of platformio or not including some library?
[env:lolin_s2_mini]
board = lolin_s2_mini
FS
SD
adafruit/Adafruit TinyUSB Library@^1.10.3
Edit:
Compiler message
====================[ Build | Production | lolin_s2_mini ]======================
C:\Users\jakub\AppData\Local\JetBrains\Toolbox\apps\CLion\ch-0\222.2889.11\bin\cmake\win\bin\cmake.exe --build C:\Users\jakub\CLionProjects\macropad\cmake-build-lolin_s2_mini --target Production -j 3
[1/1] cmd.exe /C "cd /D C:\Users\jakub\CLionProjects\macropad && platformio -c clion run -elolin_s2_mini"
FAILED: CMakeFiles/Production C:/Users/jakub/CLionProjects/macropad/cmake-build-lolin_s2_mini/CMakeFiles/Production
Processing lolin_s2_mini (platform: espressif32; board: lolin_s2_mini; framework: arduino)
Removing unused dependencies...
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/lolin_s2_mini.html
PLATFORM: Espressif 32 (4.4.0) > WEMOS LOLIN S2 Mini
HARDWARE: ESP32S2 240MHz, 320KB RAM, 4MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-arduinoespressif32 @ 3.20003.0 (2.0.3)
- toolchain-riscv32-esp @ 8.4.0+2021r2-patch3
- toolchain-xtensa-esp32s2 @ 8.4.0+2021r2-patch3
Library Manager: Installing Adafruit_I2CDevice
Warning! Could not find the package with 'Adafruit_I2CDevice' requirements for your system 'windows_amd64'
Found 65 compatible libraries
|-- Adafruit SSD1306 @ 2.5.3
| |-- Adafruit GFX Library @ 1.11.1
| | |-- Adafruit BusIO @ 1.11.6
| | | |-- Wire @ 2.0.0
| | | |-- SPI @ 2.0.0
| | |-- Wire @ 2.0.0
| | |-- SPI @ 2.0.0
| |-- SPI @ 2.0.0
| |-- Wire @ 2.0.0
| | |-- Wire @ 2.0.0
| | |-- SPI @ 2.0.0
| |-- Wire @ 2.0.0
| |-- SPI @ 2.0.0
|-- Keypad @ 3.1.1
|-- FS @ 2.0.0
|-- SD @ 2.0.0
| |-- FS @ 2.0.0
| |-- SPI @ 2.0.0
|-- tcMenu @ 2.3.1
| |-- IoAbstraction @ 2.3.1
| | |-- Wire @ 2.0.0
| | |-- SimpleCollections @ 1.2.0
| | |-- TaskManagerIO @ 1.3.3
| | | |-- ESP32 BLE Arduino @ 2.0.0
| | |-- EEPROM @ 2.0.0
| |-- Wire @ 2.0.0
| |-- EEPROM @ 2.0.0
|-- U8g2 @ 2.33.4
| |-- SPI @ 2.0.0
| |-- Wire @ 2.0.0
|-- SimpleCLI @ 1.1.3
|-- Regexp @ 0.1.0
|-- Adafruit TinyUSB Library @ 1.10.3
|-- Preferences @ 2.0.0
| |-- Wire @ 2.0.0
| |-- SPI @ 2.0.0
|-- EEPROM @ 2.0.0
|-- Wire @ 2.0.0
Compiling .pio\build\lolin_s2_mini\src\MacroKeypad.cpp.o
Compiling .pio\build\lolin_s2_mini\src\cli.cpp.o
Compiling .pio\build\lolin_s2_mini\src\hidHandler.cpp.o
Compiling .pio\build\lolin_s2_mini\src\keyAction.cpp.o
In file included from .pio/libdeps/lolin_s2_mini/Adafruit TinyUSB Library/src/tusb_option.h:176,
from .pio/libdeps/lolin_s2_mini/Adafruit TinyUSB Library/src/Adafruit_TinyUSB.h:34,
from src/hidHandler.cpp:3:
.pio/libdeps/lolin_s2_mini/Adafruit TinyUSB Library/src/common/tusb_mcu.h:276:4: warning: #warning "TUP_DCD_ENDPOINT_MAX is not defined for this MCU, default to 8" [-Wcpp]
Compiling .pio\build\lolin_s2_mini\src\macroPreferences.cpp.o
src/hidHandler.cpp:9:45: error: 'hid_report_type_t' has not been declared
void hid_report_callback(uint8_t report_id, hid_report_type_t report_type, uint8_t const *buffer, uint16_t bufsize) {
src/hidHandler.cpp: In function 'void hid_report_callback(uint8_t, int, const uint8_t*, uint16_t)':
src/hidHandler.cpp:14:24: error: 'HID_REPORT_TYPE_OUTPUT' was not declared in this scope
if (report_type != HID_REPORT_TYPE_OUTPUT) return;
src/hidHandler.cpp: At global scope:
src/hidHandler.cpp:22:17: error: 'TUD_HID_REPORT_DESC_KEYBOARD' was not declared in this scope
TUD_HID_REPORT_DESC_KEYBOARD()
src/hidHandler.cpp:27:1: error: 'Adafruit_USBD_HID' does not name a type
Adafruit_USBD_HID usb_hid(desc_hid_report, sizeof(desc_hid_report), HID_ITF_PROTOCOL_KEYBOARD, 2, false);
src/hidHandler.cpp:30:22: error: 'HID_KEY_ARROW_RIGHT' was not declared in this scope
uint8_t hidcode[] = {HID_KEY_ARROW_RIGHT, HID_KEY_ARROW_LEFT, HID_KEY_ARROW_DOWN, HID_KEY_ARROW_UP};
Compiling .pio\build\lolin_s2_mini\src\main.cpp.o
src/hidHandler.cpp:30:43: error: 'HID_KEY_ARROW_LEFT' was not declared in this scope
src/hidHandler.cpp:30:63: error: 'HID_KEY_ARROW_DOWN' was not declared in this scope
src/hidHandler.cpp:30:83: error: 'HID_KEY_ARROW_UP' was not declared in this scope
Compiling .pio\build\lolin_s2_mini\src\menu_menu.cpp.o
src/hidHandler.cpp: In function 'void setupHid()':
src/hidHandler.cpp:46:5: error: 'usb_hid' was not declared in this scope
usb_hid.setReportCallback(NULL, hid_report_callback);
src/hidHandler.cpp:51:13: error: 'TinyUSBDevice' was not declared in this scope
while (!TinyUSBDevice.mounted()) delay(1);
src/hidHandler.cpp: In function 'void sendKey()':
src/hidHandler.cpp:65:9: error: 'TinyUSBDevice' was not declared in this scope
if (TinyUSBDevice.suspended() && count) {
src/hidHandler.cpp:72:10: error: 'usb_hid' was not declared in this scope
if (!usb_hid.ready()) return;
src/hidHandler.cpp:81:9: error: 'usb_hid' was not declared in this scope
usb_hid.keyboardReport(report_id, modifier, keycode);
src/hidHandler.cpp:88:13: error: 'usb_hid' was not declared in this scope
usb_hid.keyboardRelease(0);
*** [.pio\build\lolin_s2_mini\src\hidHandler.cpp.o] Error 1
========================= [FAILED] Took 18.90 seconds =========================
ninja: build stopped: subcommand failed.
