@ivankravets You might want to have a look at it…
I was notified of problem in the CI of a popular Arduino library that might be related to the new PIO Core version. I’ve isolated the problem to a simple project. It fails to compile:
[env:esp32doit-devkit-v1]
board = esp32doit-devkit-v1
DHT sensor library
#include <DHT.h>
void setup() { }
void loop() { }
> Executing task in folder DHT: platformio run <
Processing esp32doit-devkit-v1 (platform: espressif32; board: esp32doit-devkit-v1; framework: arduino)
PLATFORM: Espressif 32 (1.12.4) > DOIT ESP32 DEVKIT V1
Library Manager: Installing DHT sensor library
Library Manager: DHT sensor library @ 1.3.10 has been installed!
Library Manager: Installing dependencies...
Library Manager: Installing Adafruit Unified Sensor
Library Manager: Adafruit Unified Sensor @ 1.1.4 has been installed!
Found 28 compatible libraries
|-- <DHT sensor library> 1.3.10
Compiling .pio/build/esp32doit-devkit-v1/src/main.cpp.o
Generating partitions .pio/build/esp32doit-devkit-v1/partitions.bin
Compiling .pio/build/esp32doit-devkit-v1/lib8ae/DHT sensor library/DHT.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/lib8ae/DHT sensor library/DHT_U.cpp.o
Archiving .pio/build/esp32doit-devkit-v1/libFrameworkArduinoVariant.a
Indexing .pio/build/esp32doit-devkit-v1/libFrameworkArduinoVariant.a
In file included from .pio/libdeps/esp32doit-devkit-v1/DHT sensor library/DHT_U.cpp:15:0:
.pio/libdeps/esp32doit-devkit-v1/DHT sensor library/DHT_U.h:36:29: fatal error: Adafruit_Sensor.h: No such file or directory
* Looking for Adafruit_Sensor.h dependency? Check our library registry!
* CLI > platformio lib search "header:Adafruit_Sensor.h"
* Web > https://platformio.org/lib/search?query=header:Adafruit_Sensor.h
#include <Adafruit_Sensor.h>
compilation terminated.
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/Esp.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/FunctionalInterrupt.cpp.o
*** [.pio/build/esp32doit-devkit-v1/lib8ae/DHT sensor library/DHT_U.cpp.o] Error 1
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/HardwareSerial.cpp.o
======================================================================================================================= [FAILED] Took 2.65 seconds =======================================================================================================================
The terminal process "platformio 'run'" terminated with exit code: 1.
Even though the library Adafruit Unified Sensor (a dependency of DHT) is downloaded (see log), but it does not appear as a dependency and the necessary include path is not added.
If the library is explicitly declared in platformio.ini, it works.
