I’m trying to write the Adafruit ADXL343 demo sketch (https://github.com/adafruit/Adafruit_ADXL343/blob/master/examples/sensortest/sensortest.ino) to an Adafruit Metro Mini, which is basically equivalent to an Arduino Uno.
My platformio.ini looks like this:
[env:uno]
board = uno
board_build.mcu = atmega328p
;lib_compat_mode = off
;lib_ldf_mode = deep+
adafruit/Adafruit ADXL343
adafruit/Adafruit Unified Sensor
While the resolver does find and download relevant libraries, during a run attempt it disregards them as incompatible:
$ bin/pio run -v
Processing uno (platform: atmelavr; board: uno; board_build.mcu: atmega328p; lib_deps: adafruit/Adafruit ADXL343, adafruit/Adafruit Unified Sensor)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (4.0.0) > Arduino Uno
Framework incompatible library /[...]/.pio/libdeps/uno/Adafruit ADXL343
Framework incompatible library /[...]/.pio/libdeps/uno/Adafruit BusIO
Framework incompatible library /[...]/.pio/libdeps/uno/Adafruit Unified Sensor
More details about "Library Compatibility Mode": https://docs.platformio.org/page/librarymanager/ldf.html#ldf-compat-mode
Found 1 compatible libraries
avr-gcc -o .pio/build/uno/src/main.o -c -std=gnu11 -fno-fat-lto-objects -mmcu=atmega328p -Os -Wall -ffunction-sections -fdata-sections -flto -DF_CPU=16000000L -DPLATFORMIO=60103 -DARDUINO_AVR_UNO -Iinclude -Isrc src/main.c
src/main.c:1:10: fatal error: Adafruit_Sensor.h: No such file or directory
However, the library.properties file in those library directories don’t appear to specify any limitation (they show architectures=*
, but I don’t know if that’s relevant).
Changing the compat_mode and ldf_mode settings don’t cause it to find those libraries acceptable.
Am I missing something? Switching to Windows and the Arduino IDE, I was able to flash the sketch successfully, so I think these libraries should be compatible.
