I have an DOIT ESP32 Devkit board that I have been experimenting with, transmissing data via sockets over WiFi.
My initial development was on a MAC using the Espressif IDE with idf.py command line to build, install and monitor.
I recently decided to try the IOPlatform on a Windows PC. Installed IPlatform, and configured it for the ESP32. Ported the code over from the MAC and tried to build. Mostly it was successful. However there are a number of enums which seem to be missing. For example the tcpip_adaptor.h file on the MAC contains the following declarations:
/** IP event declarations */
typedef enum {
IP_EVENT_STA_GOT_IP, /*!< ESP32 station got IP from connected AP */
IP_EVENT_STA_LOST_IP, /*!< ESP32 station lost IP and the IP is reset to 0 */
IP_EVENT_AP_STAIPASSIGNED, /*!< ESP32 soft-AP assign an IP to a connected station */
IP_EVENT_GOT_IP6, /*!< ESP32 station or ap or ethernet interface v6IP addr is preferred */
IP_EVENT_ETH_GOT_IP, /*!< ESP32 ethernet got IP from connected AP */
} ip_event_t;
These are not present in the tcpip_adaptor.h installed with IOPlatform.
Similarly esp_wifi_types.h does not contain the WiFi event declaration enum:
typedef enum {
WIFI_EVENT_WIFI_READY = 0, /**< ESP32 WiFi ready */
WIFI_EVENT_SCAN_DONE, /**< ESP32 finish scanning AP */
WIFI_EVENT_STA_START, /**< ESP32 station start */
WIFI_EVENT_STA_STOP, /**< ESP32 station stop */
WIFI_EVENT_STA_CONNECTED, /**< ESP32 station connected to AP */
WIFI_EVENT_STA_DISCONNECTED, /**< ESP32 station disconnected from AP */
WIFI_EVENT_STA_AUTHMODE_CHANGE, /**< the auth mode of AP connected by ESP32 station
Can I ask if this is to be expected. ie. Do we have a different set of libraries and operation mechanisms under IOPlatform (and therefore I will need to trawl through the examples to determine what I need to do) or have I got the configuration wrong.
Thanks
