Hello. I’ve been trying to use Plattform.io as an Arduino editor (mainly for ESP) for a couple of weeks now. I often have problems with the library integrations - It compiles without problems in Arduino IDE, but raises many errors in Plattform.io. For example, i needed to copy the SD library from Arduino into the lib folder because the “internal” library for the ESP32 did not work (although it should be the same).
Current problem which i dont understand: I use AsyncElegantOTA (togetger with ESPAsyncWebServer). The AsyncElegantOTA library ( ayushsharma82/AsyncElegantOTA @ ^2.2.5) did install without any problems, but although the AsyncElegantOTA .h header file is clearly in the library source folder, i get an error (it seems AsyncElegantOTA is not added to the dependency graph althouhg included):
Processing esp-wrover-kit (platform: espressif32; board: esp-wrover-kit; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp-wrover-kit.html
PLATFORM: Espressif 32 (3.2.0) > Espressif ESP-WROVER-KIT
DEBUG: Current (ftdi) On-board (ftdi) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
LDF Modes: Finder ~ chain, Compatibility ~ strict
Found 30 compatible libraries
|-- <WiFi> 1.0
|-- <ESP Async WebServer> 1.2.3
| |-- <AsyncTCP> 1.1.1
| |-- <FS> 1.0
| |-- <WiFi> 1.0
|-- <AsyncTCP> 1.1.1
Compiling .pio\build\esp-wrover-kit\src\main.cpp.o
Archiving .pio\build\esp-wrover-kit\lib79f\libWiFi.a
Archiving .pio\build\esp-wrover-kit\libd37\libAsyncTCP.a
Compiling .pio\build\esp-wrover-kit\libe01\FS\FS.cpp.o
Compiling .pio\build\esp-wrover-kit\libe01\FS\vfs_api.cpp.o
Compiling .pio\build\esp-wrover-kit\lib03b\ESP Async WebServer\AsyncEventSource.cpp.o
Compiling .pio\build\esp-wrover-kit\lib03b\ESP Async WebServer\AsyncWebSocket.cpp.o
Compiling .pio\build\esp-wrover-kit\lib03b\ESP Async WebServer\SPIFFSEditor.cpp.o
Compiling .pio\build\esp-wrover-kit\lib03b\ESP Async WebServer\WebAuthentication.cpp.o
Compiling .pio\build\esp-wrover-kit\lib03b\ESP Async WebServer\WebHandlers.cpp.o
Compiling .pio\build\esp-wrover-kit\lib03b\ESP Async WebServer\WebRequest.cpp.o
Compiling .pio\build\esp-wrover-kit\lib03b\ESP Async WebServer\WebResponses.cpp.o
src\main.cpp:28:29: fatal error: AsyncElegantOTA.h: No such file or directory
* Looking for AsyncElegantOTA.h dependency? Check our library registry!
* CLI > platformio lib search "header:AsyncElegantOTA.h"
* Web > https://platformio.org/lib/search?query=header:AsyncElegantOTA.h
compilation terminated.
*** [.pio\build\esp-wrover-kit\src\main.cpp.o] Error 1
Compiling .pio\build\esp-wrover-kit\lib03b\ESP Async WebServer\WebServer.cpp.o
Also changing the lib ldf mode to chain+ did not work.
minimal plattformio.ini:
[env:esp-wrover-kit]
board = esp-wrover-kit
lib_compat_mode = strict
lib_ldf_mode = chain+
WiFi
ESP Async WebServer
minimal sourcecode example:
#include "Arduino.h"
#include <WiFi.h>
#include <AsyncTCP.h>
#include <ESPAsyncWebServer.h>
#include <AsyncElegantOTA.h>
const char* ssid = "REPLACE_WITH_YOUR_SSID";
const char* password = "REPLACE_WITH_YOUR_PASSWORD";
AsyncWebServer server(80);
void setup(void) {
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.println("");
// Wait for connection
delay(500);
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request) {
request->send(200, "text/plain", "Hi! I am ESP8266.");
AsyncElegantOTA.begin(&server); // Start ElegantOTA
server.begin();
Serial.println("HTTP server started");
void loop(void) {
AsyncElegantOTA.loop();
