whe trying to Include Adafruit unified sensors and DHT Sensor library VSCode throws a python error at me. Even the Example projects in the Libraries are spitting out these errors.
------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Removing unused dependencies...
File "C:\Users\marce\.platformio\penv\lib\site-packages\platformio\__main__.py", line 102, in main
File "C:\Users\marce\.platformio\penv\lib\site-packages\click\core.py", line 1130, in __call__
File "C:\Users\marce\.platformio\penv\lib\site-packages\click\core.py", line 1055, in main
rv = self.invoke(ctx)
File "C:\Users\marce\.platformio\penv\lib\site-packages\platformio\cli.py", line 71, in invoke
return super().invoke(ctx)
File "C:\Users\marce\.platformio\penv\lib\site-packages\click\core.py", line 1657, in invoke
File "C:\Users\marce\.platformio\penv\lib\site-packages\click\core.py", line 1404, in invoke
File "C:\Users\marce\.platformio\penv\lib\site-packages\click\core.py", line 760, in invoke
File "C:\Users\marce\.platformio\penv\lib\site-packages\click\decorators.py", line 26, in new_func
File "C:\Users\marce\.platformio\penv\lib\site-packages\platformio\run\cli.py", line 144, in cli
process_env(
File "C:\Users\marce\.platformio\penv\lib\site-packages\platformio\run\cli.py", line 201, in process_env
result = {"env": name, "duration": time(), "succeeded": ep.process()}
File "C:\Users\marce\.platformio\penv\lib\site-packages\platformio\run\processor.py", line 83, in process
install_project_env_dependencies(
File "C:\Users\marce\.platformio\penv\lib\site-packages\platformio\package\commands\install.py", line 132, in install_project_env_dependencies
_install_project_env_libraries(project_env, options),
File "C:\Users\marce\.platformio\penv\lib\site-packages\platformio\package\commands\install.py", line 204, in _install_project_env_libraries
_uninstall_project_unused_libdeps(project_env, options)
File "C:\Users\marce\.platformio\penv\lib\site-packages\platformio\package\commands\install.py", line 280, in _uninstall_project_unused_libdeps
lm.uninstall(spec)
File "C:\Users\marce\.platformio\penv\lib\site-packages\platformio\package\manager\_uninstall.py", line 29, in uninstall
return self._uninstall(spec, skip_dependencies)
File "C:\Users\marce\.platformio\penv\lib\site-packages\platformio\package\manager\_uninstall.py", line 34, in _uninstall
pkg = self.get_package(spec)
File "C:\Users\marce\.platformio\penv\lib\site-packages\platformio\package\manager\base.py", line 263, in get_package
spec = self.ensure_spec(spec)
File "C:\Users\marce\.platformio\penv\lib\site-packages\platformio\package\manager\base.py", line 133, in ensure_spec
return spec if isinstance(spec, PackageSpec) else PackageSpec(spec)
File "C:\Users\marce\.platformio\penv\lib\site-packages\platformio\package\meta.py", line 184, in __init__
self._parse(self.raw)
File "C:\Users\marce\.platformio\penv\lib\site-packages\platformio\package\meta.py", line 291, in _parse
raw = parser(raw)
File "C:\Users\marce\.platformio\penv\lib\site-packages\platformio\package\meta.py", line 316, in _parse_requirements
self.requirements = tokens[1].strip()
File "C:\Users\marce\.platformio\penv\lib\site-packages\platformio\package\meta.py", line 231, in requirements
else semantic_version.SimpleSpec(str(value))
File "C:\Users\marce\.platformio\penv\lib\site-packages\semantic_version\base.py", line 647, in __init__
self.clause = self._parse_to_clause(expression)
File "C:\Users\marce\.platformio\penv\lib\site-packages\semantic_version\base.py", line 1043, in _parse_to_clause
return cls.Parser.parse(expression)
File "C:\Users\marce\.platformio\penv\lib\site-packages\semantic_version\base.py", line 1063, in parse
raise ValueError("Invalid simple block %r" % block)
ValueError: Invalid simple block '^1.4.3;'
`pip install -U platformio` command
