Hello. Buid-in lib WebServer.h (platform espressif 32, framework arduinoespressif32, boards: esp wroom32) had updated recently. Now i have a problem whith my Captive portal. I know it is because this lib was update, it is works in ArduinoIDE and I comapare dates of file and they are different. may you update this library?
Unfortunately, you do not specify which platform, which framework, which board, which versions, which exact library etc. is involved.
Maybe you can share your platformio.ini and a smallest possible sketch to reproduce the issue?
The information needed to reproduce the problem is still missing. Please share your platformio.ini and a minimal sketch that allows to reproduce the problem.
In your screenshot I can see you’re using Arduino Core 3.0.1 in ArduinoIDE.
This version is not yet available in PlatformIO.
Arduino 3.0.1 has some breaking API changes!
I mean “In your screenshot I can see you’re using Arduino Core 3.0.1 in ArduinoIDE.
This version is not yet available in PlatformIO” is that I told. So I must wait when it wil be available. Thank you
You can try
platform_packages=
framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git#3.0.1
framework-arduinoespressif32-libs @ https://github.com/espressif/arduino-esp32/releases/download/3.0.1/esp32-arduino-libs-3.0.1.zip
See Can't get esp32-arduino 3.0.0rc1 installed - #4 by bcsabadiy
Did you wait until all tasks (installing the necessary packages) has been finished?
Downloading the packages can take a few minutes.
Also clean your project to remove build artifacts.
Create a new (temporary) test project (“Hello World”) and try to build it with the settings mentioned above to see if a 3.0.1 project compiles without issues.
