The library is not registered with the library registry (PlatformIO Registry). So you either have to download https://werner.rothschopf.net/2019/NoiascaLedControl.zip manually and put the library in the lib/ folder of the project, or add lib_deps = https://werner.rothschopf.net/2019/NoiascaLedControl.zip in the platformio.ini of the project. I would heavily recommand a local copy though, because you don’t know when that blog site eventually goes down.
