Lib_extra_dirs relative path
Hi PlatfromIO Community,
I have succesfully created a library named “common” with it’s library.json
I need to include this lib to multiple projects (test_project_a, test_project_b)
librairies/
└── common/
├── utils.hpp
├── utils.cpp
└── library.json
test_project_a/
├── platfromio.ini
└── src/
└── main.cpp
test_project_b/
├── platfromio.ini
└── src/
└── main.cpp
To each test project platfromio.ini I added the following lines and it’s working:
lib_extra_dirs = F:\my_absolute_path\librairies
lib_deps = common
but i would want to use a relative path to share the project with my team members:
lib_extra_dirs = …/librairies
lib_deps = common
Do you have some ideas to get this working ?
Thanks !
Are you on windows or linux? On my ubuntu it works with lib_extra_dirs = …/lib, try using …\libraries.
Or try changing your libraries structure to
librairies/
└── common/
└──utils/
├── utils.hpp
├── utils.cpp
└── library.json
Sorry for formating can’t find how to put tabs. What I mean is try putting utils.c and .h into separate folder utils.
Thanks for the help,
I made a mistake on the first post about the libraries folder structure, the correct one is:
librairies/
└── common/
    ├── utils.hpp
    ├── utils.cpp
    └── library.json
test_project_a/
    ├── platfromio.ini
    └── src/
        └── main.cpp
test_project_b/
    ├── platfromio.ini
    └── src/
        └── main.cpp
I tried the following without success:
lib_extra_dirs = F:\my_absolute_path\librairies ;working
lib_extra_dirs = …\librairies ;not working
lib_extra_dirs = …/librairies ;not working
I’m on win10.
As the relative path is not working, maybe another solution would be using dynamic variables
Something like this is in the example on the dynamic variables pages but i can’t find a variable for current project folder like:
lib_extra_dirs = ${current_project_folder}..\libraries
Also, by looking at this thread
I tried the following without succes:
lib_extra_dirs = ..\..\librairies
I also tried putting my library “common” in my project lib/ folder, everything is working correctly in this case.
Further informations:
case 1
lib_extra_dirs = F:\my_path\librairies
Found 5 compatible libraries
|-- <common> 0.0.0
SUCCESS
case 2
lib_extra_dirs = …\librairies ;same result with …/librairies
lib_deps = common
|-- <common>
src\main.cpp:1:10: fatal error: utils/Utils.hpp: No such file or directory
FAILED
case 3
lib_extra_dirs = …\librairies ;same result with …/…/librairies
lib_deps = common
|-- <common>
FAILED
here is for reference my library.json
	"frameworks": "mbed",
	"name": "common",
	"platforms": "*",
	"version": "0.0.0"
Yay i finally found it by accident on this page :smile:
All is now working with:
lib_extra_dirs = ${PROJECT_DIR}\..\librairies
Huh I missed the page with all built in variables on the doc when i was searching for them, it was here
https://docs.platformio.org/en/latest/projectconf/section_env_build.html#built-in-variables
There’s a working example of another solution to this (the above didn’t work for me) at the following GITHUB platformIO project: GitHub - LoringEcm/ESP-3248S035-CYD35_test: Test code for the ESP32-3248S035C Cheap Yellow Display (CYD) in a PlatformIO project demonstrating how to draw simple graphics, process the 'touch' screen, and use the Wireless interface. · GitHub
