I am using CLion and the PlatformIO plugin with a microbit v2 board. I am just trying to get started on some basic LED blinking and followed the directions on the PlatformIO docs. I tried following the PlatformIO CLion docs to get started and it seemed to build and upload fine, but I did not notice any changes on the board or any blinking. https://docs.platformio.org/en/stable/integration/ide/clion.html#ide-clion
This example used was for Arduino but I thought microbitv2 was arduino as well and should have worked.
Since I didn’t notice any blinking from the CLion example, I tried pulling in a basic microbitv2 sample from here
However, this fails to build because it is not recognizing the Microbit.h header. I have tried #include "MicroBit.h"
and #include <MicroBit.h>
This is the library I’m trying to pull in, here is my lib_deps which matches
I see, I think the framework = arduino was added when creating the project when I chose the microbit v2 board. When I look at the PlatformIO board docs, it looks like only Arduino and Zephyr RTOS are supported for this board. So that means I can’t use PlatformIO with an mbed-os framwork, correct?
I don’t mind using Arduino, but I’m not sure how to program this board in an Arduino framework since all those examples linked above are mbed-os. Does PlatformIO support any way for me to build those examples in that framework using the micro:bit V2 board?
Also from your previous response, I understand now the lib_deps documentation states that the compatibility defaults to soft, which will check compatibility with framework. Since as you mentioned, the library I was trying to pull in was mbed-os and my build framework was Arduino, it would not meet this compatibility requirement and would not pull in that header file.
