Hi there,
I have installed an external library into my Pio project using "pio lib install /path/to/library"
Then I use the .gcc-flags.json file to modify the gccIncludePaths to include “…/.piolibdeps” to the folders that I will be referencing.
I also change the .clang_complete file to include the -I/path/to/library. However, when I build the project, it does not try to compile with the libraries I am attempting to link. And using #include for the header files I want to use simply throws the error that they are not available.
How do I get the IDE to recognize the paths and compile my lib_dep sources?
Thank you in advance!
What does mean lib_dep
? Why you edit manually PlatformIO’s system files?
lib_dep are the library dependents. I then link it in the gcc-flags file so that it will compile.
I edited the system files manually because I couldn’t get them to update!
- It should be lib_deps, not “lib_dep”
- Please don’t touch
.gcc-flags.json
, PlatformIO will generate valid config automatically when you use correct options.
I have modified platform.ini to include the lib_deps library that I have installed. However, when I try to build, it still tells me that the library has not been found in the PlatformIO registry. It does not find the file or the library tree that I am trying to compile.
Which library isn’t in repository? Please share platformio.ini
file here.
It tells me that Library_ff087 is not in the repository. Although I have used pio lib install, and it checks in just fine.
[env:due]
platform = atmelsam
board = due
lib_deps = Library_ff087
lib_extra_dirs = ~/.piolibdeps/Library_60f06
Please read the documentation before http://docs.platformio.org. You don’t need lib_extra_dirs
, also use library name for lib_deps
How do I know what the library name is? I just took it from pio lib list
It’s not in there, that is why I’m trying to link it myself!
Check “lib/readme.txt” in the project folder
круто. Дякую. Cool, thanks.
Вийшло, земляк? Щось ти мучишся довго
Мій дід з Львів. Я щойно відвідав. Дякуємо ти за програмне!
