I am trying to use STemWin (graphic library provided by ST as part of STM32CubeF7 framework ) but cannot compile it successfully.
I get error because the PIO doesn’t find a header file LCDConf.h (which is in my projects inc/ folder), which is referenced from one of the librarie’s .c source file.
I’ve read the Note in the LDF documentation and tried changing lib_ldf_mode to deep (and others too) - but the error stays the same.
Could it be that the lib_ldf_mode doesn’t work?
Also, I didn’t quite understand the first part of the “Note” in the LDF docs saying “…explicitly reference the dependency from the project source…” → what does this mean (for dummies)?
The lib_deps option described is not suitable for my case, as this library is not part of PIO registry or anything. Should I create a library.json and then use the lib_deps option?
And lastly, how should I treat cases like this - where I want to use libraries that are part of the STM32Cube package, but are not actually part of the PIO stm32cube framework (only HAL and CMSIS stuff there afaik)? I don’t (want to) know anything about internal structure of the library, but want to use it in my project…should I write library.json myself? What I am doing now is using lib_extra_dirs option w/ manually downloaded STM32Cube package…but since the libraries are of all sorts of structures, I often get some missing dependency errors ![]()
My project conf:
[platformio]
env_default = disco_f746ng
build_dir = pio_builds
include_dir = inc
[env:disco_f746ng]
platform = ststm32
board = disco_f746ng
framework = stm32cube
upload_protocol = stlink
lib_ldf_mode = deep
lib_extra_dirs = /home/jure/Projects/ARMdev_stuff/STM32Cube_FW_F7_V1.11.0/Drivers/BSP, /home/jure/Projects/ARMdev_stuff/STM32Cube_FW_F7_V1.11.0/Middlewares/ST/STemWin
Project structure:
├── inc
│ ├── GUIConf.h
│ └── LCDConf.h
├── lib
│ └── readme.txt
├── pio_builds
│ ├── do-not-modify-files-here.url
│ └── structure.hash
├── src
│ ├── GUIConf.c
│ ├── LCDConf.c
│ └── main.c
└── platformio.ini
STemWin library structure (part of STM32Cube F7 software package in STM32CubeF7/Middlewares/ST/STemWin/):
├── Config
│ ├── GUIConf.c
│ ├── GUIConf.h
│ ├── GUIDRV_Template.c
│ ├── GUIDRV_Template.h
│ ├── LCDConf_FlexColor_Template.c
│ ├── LCDConf_FlexColor_Template.h
│ ├── LCDConf_Lin_Template.c
│ ├── LCDConf_Lin_Template.h
│ └── SIMConf.c
├── Documentation
│ └── STemWin540.pdf
├── inc
│ ├── BUTTON.h
│ ├── BUTTON_Private.h
│ ├── CALENDAR.h
│ ├── CHECKBOX.h
│ ├── CHECKBOX_Private.h
│ ├── CHOOSECOLOR.h
│ ├── CHOOSEFILE.h
│ ├── DIALOG.h
│ ├── DIALOG_Intern.h
│ ├── DROPDOWN.h
│ ├── DROPDOWN_Private.h
│ ├── EDIT.h
│ ├── EDIT_Private.h
│ ├── FRAMEWIN.h
│ ├── FRAMEWIN_Private.h
│ ├── Global.h
│ ├── GRAPH.h
│ ├── GRAPH_Private.h
│ ├── GUI_ARRAY.h
│ ├── GUI_ARRAY_Private.h
│ ├── GUI__BiDi2_Brackets_800.h
│ ├── GUI__BiDi2_Types_800.h
│ ├── GUI_BMP_Private.h
│ ├── GUI_ConfDefaults.h
│ ├── GUI_Debug.h
│ ├── GUIDRV_DCache.h
│ ├── GUIDRV_DCache_Private.h
│ ├── GUIDRV_Dist.h
│ ├── GUIDRV_FlexColor.h
│ ├── GUIDRV_FlexColor_Private.h
│ ├── GUIDRV_Lin.h
│ ├── GUIDRV_Lin_Opt_16.h
│ ├── GUIDRV_Lin_Opt_24.h
│ ├── GUIDRV_Lin_Opt_32.h
│ ├── GUIDRV_Lin_Opt_8.h
│ ├── GUIDRV_Lin_Private.h
│ ├── GUIDRV_NoOpt_1_8.h
│ ├── GUIDRV_TemplateI.h
│ ├── GUIDRV_TemplateI_Private.h
│ ├── GUI_FontIntern.h
│ ├── GUI_GCache_Private.h
│ ├── GUI_GIF_Private.h
│ ├── GUI.h
│ ├── GUI_HOOK.h
│ ├── GUI_JPEG_Private.h
│ ├── GUIMTDRV_TangoC32.h
│ ├── GUI_Private.h
│ ├── GUI_SetOrientationCX.h
│ ├── GUI_SetOrientation.h
│ ├── GUI_SIM_Win32.h
│ ├── GUI_SPRITE_Private.h
│ ├── GUITDRV_ADS7846.h
│ ├── GUI_Type.h
│ ├── GUI_Version.h
│ ├── GUI_VNC.h
│ ├── HEADER.h
│ ├── HEADER_Private.h
│ ├── ICONVIEW.h
│ ├── ICONVIEW_Private.h
│ ├── IMAGE.h
│ ├── IMAGE_Private.h
│ ├── IP_FS.h
│ ├── KNOB.h
│ ├── KNOB_Private.h
│ ├── LCD_ConfDefaults.h
│ ├── LCD.h
│ ├── LCD_Private.h
│ ├── LCD_Protected.h
│ ├── LCD_SIM.h
│ ├── LISTBOX.h
│ ├── LISTBOX_Private.h
│ ├── LISTVIEW.h
│ ├── LISTVIEW_Private.h
│ ├── LISTWHEEL.h
│ ├── LISTWHEEL_Private.h
│ ├── MENU.h
│ ├── MENU_Private.h
│ ├── MESSAGEBOX.h
│ ├── MULTIEDIT.h
│ ├── MULTIPAGE.h
│ ├── MULTIPAGE_Private.h
│ ├── PROGBAR.h
│ ├── PROGBAR_Private.h
│ ├── RADIO.h
│ ├── RADIO_Private.h
│ ├── SCROLLBAR.h
│ ├── SCROLLBAR_Private.h
│ ├── SEGGER.h
│ ├── SLIDER.h
│ ├── SLIDER_Private.h
│ ├── SPINBOX.h
│ ├── SPINBOX_Private.h
│ ├── SWIPELIST.h
│ ├── SWIPELIST_Private.h
│ ├── TEXT.h
│ ├── TEXT_Private.h
│ ├── TREEVIEW.h
│ ├── TREEVIEW_Private.h
│ ├── WIDGET.h
│ ├── WINDOW_Private.h
│ ├── WM_GUI.h
│ ├── WM.h
│ └── WM_Intern.h
├── Lib
│ ├── MCD-ST Image SW License Agreement V2.pdf
│ ├── STemWin540_CM7_GCC.a
│ ├── STemWin540_CM7_GCC_ARGB.a
│ ├── STemWin540_CM7_GCC_ot.a
│ ├── STemWin540_CM7_GCC_ot_ARGB.a
│ ├── STemWin540_CM7_IAR.a
│ ├── STemWin540_CM7_IAR_ARGB.a
│ ├── STemWin540_CM7_IAR_ot.a
│ ├── STemWin540_CM7_IAR_ot_ARGB.a
│ ├── STemWin540_CM7_Keil_ARGB.lib
│ ├── STemWin540_CM7_Keil.lib
│ ├── STemWin540_CM7_Keil_ot_ARGB.lib
│ ├── STemWin540_CM7_Keil_ot.lib
│ ├── STemWin540_CM7_OS_GCC.a
│ ├── STemWin540_CM7_OS_GCC_ARGB.a
│ ├── STemWin540_CM7_OS_GCC_ot.a
│ ├── STemWin540_CM7_OS_GCC_ot_ARGB.a
│ ├── STemWin540_CM7_OS_IAR.a
│ ├── STemWin540_CM7_OS_IAR_ARGB.a
│ ├── STemWin540_CM7_OS_IAR_ot.a
│ ├── STemWin540_CM7_OS_IAR_ot_ARGB.a
│ ├── STemWin540_CM7_OS_Keil_ARGB.lib
│ ├── STemWin540_CM7_OS_Keil.lib
│ ├── STemWin540_CM7_OS_Keil_ot_ARGB.lib
│ ├── STemWin540_CM7_OS_Keil_ot.lib
│ ├── STemWin540_WIN32_ARGB.lib
│ └── STemWin540_WIN32.lib
├── OS
│ ├── GUI_X.c
│ └── GUI_X_OS.c
├── Simulation
│ ├── GUISim.lib
│ ├── SimulationMinGW.res
│ └── WinMain.c
├── Software
│ ├── JPEG2MovieScripts
│ │ ├── 120x68.bat
│ │ ├── 160x120.bat
│ │ ├── 160x90.bat
│ │ ├── 200x150.bat
│ │ ├── 240x136.bat
│ │ ├── 240x180.bat
│ │ ├── 320x180.bat
│ │ ├── 320x240.bat
│ │ ├── 480x272.bat
│ │ ├── 80x45.bat
│ │ ├── 80x60.bat
│ │ ├── MakeMovie.bat
│ │ └── Prep.bat
│ ├── Bin2C.exe
│ ├── BmpCvtST.exe
│ ├── emVNC.exe
│ ├── emWinPlayer.exe
│ ├── FontCvtST.exe
│ ├── GUIBuilder.exe
│ ├── JPEG2Movie.exe
│ └── U2C.exe
└── Release_Notes.html
