LDF Bug, can't find dependency during build phase but manually installs fine
esp8266-google-home-notifier has a dependency esp8266-google-tts and both are registered libraries, but for some reason pio cannot find the dependency in the build phase, only if it is installed manually. See output.
 …/tempp  ✔  pio run
Processing e (platform: espressif32; board: featheresp32; framework: arduino)
LibraryManager: Installing id=5425
Downloading...
Unpacking  [####################################]  100%
PLATFORM: Espressif 32 > Adafruit ESP32 Feather
SYSTEM: ESP32 240MHz 320KB RAM (4MB Flash)
DEBUG: CURRENT(esp-prog) EXTERNAL(esp-prog, minimodule, olimex-arm-usb-ocd, olimex-arm-usb- ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny)
Collected 25 compatible libraries
Error: Could not find `esp8266-google-tts` dependency for `esp8266-google-home-notifier` library
=================================== [ERROR] Took 1.81 seconds ===================================
 …/tempp  ↵ 1  vi platformio.ini
 …/tempp  ✔  pio lib search esp8266-google-tts
Found 1 libraries:
esp8266-google-tts
#ID: 2751
generate the link to speech mp3 on esp8266/32.
Keywords: processing, data
Compatible frameworks: Arduino
Compatible platforms: Espressif 32, Espressif 8266
Authors: horihiro
Not sure why its not fetching the dependency automatically.
 …/tempp  ↵ 1  pio --version
PlatformIO, version 3.6.0
Could you share platformio.ini? Have you declared dependencies in Redirecting...?
Yep, this is what I was using (which usually works)
; http://docs.platformio.org/page/projectconf.html
[env:e]
board = featheresp32
lib_deps = esp8266-google-home-notifier
This library was registered using Arduino’s library.properties which does not support dependencies. I’ve just sent PR Bump version to 1.0.6 by ivankravets · Pull Request #8 · horihiro/esp8266-google-home-notifier · GitHub
Let’s wait when it will be merged.
Sounds good, but that seems a bit strange since pio acknowledged that the dependency existed, but failed to look it up even though it existed.
