I thought that I will give the latest 2.0 bugfix a go (just for fun current version i use runs ok) after successfully running @maxgerhardt version of Marlin on my malyan M200.
I figured some differences between his version and the latest bugfix out but I again hit a wall. I use same settings in config files and same platformio settings but I get following errors.
Can one of you Platformio big brains have a look at it and give me some pointers again, please?
Linking .pio\build\malyanm200v2\firmware.elf
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/MarlinCore.cpp.o: in function `enable_e_steppers()':
MarlinCore.cpp:(.text._Z17enable_e_steppersv+0x20): undefined reference to `FastIOPortMap'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/MarlinCore.cpp.o: in function `enable_all_steppers()':
MarlinCore.cpp:(.text._Z19enable_all_steppersv+0x40): undefined reference to `FastIOPortMap'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/MarlinCore.cpp.o: in function `disable_e_steppers()':
MarlinCore.cpp:(.text._Z18disable_e_steppersv+0x20): undefined reference to `FastIOPortMap'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/MarlinCore.cpp.o: in function `disable_e_stepper(unsigned char)':
MarlinCore.cpp:(.text._Z17disable_e_stepperh+0x24): undefined reference to `FastIOPortMap'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/MarlinCore.cpp.o: in function `disable_all_steppers()':
MarlinCore.cpp:(.text._Z20disable_all_steppersv+0x60): undefined reference to `FastIOPortMap'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/MarlinCore.cpp.o: in function `minkill(bool)':
MarlinCore.cpp:(.text._Z7minkillb+0x5e): undefined reference to `HAL_watchdog_refresh()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/MarlinCore.cpp.o: in function `manage_inactivity(bool)':
MarlinCore.cpp:(.text._Z17manage_inactivityb[_Z17manage_inactivityb]+0x130): undefined reference to `FastIOPortMap'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/MarlinCore.cpp.o: in function `setup':
MarlinCore.cpp:(.text.setup+0x32): undefined reference to `HAL_init()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: MarlinCore.cpp:(.text.setup+0x3a): undefined reference to `HAL_get_reset_source()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: MarlinCore.cpp:(.text.setup+0x72): undefined reference to `HAL_clear_reset_source()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: MarlinCore.cpp:(.text.setup+0x128): undefined reference to `watchdog_init()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/feature/fanmux.cpp.o: in function `fanmux_switch(unsigned char)':
fanmux.cpp:(.text._Z13fanmux_switchh+0x2c): undefined reference to `FastIOPortMap'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/feature/fanmux.cpp.o: in function `fanmux_init()':
fanmux.cpp:(.text._Z11fanmux_initv+0x30): undefined reference to `FastIOPortMap'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/gcode/control/M17_M18_M84.cpp.o: in function `GcodeSuite::M17()':
M17_M18_M84.cpp:(.text._ZN10GcodeSuite3M17Ev+0xa4): undefined reference to `FastIOPortMap'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/gcode/control/M17_M18_M84.cpp.o: in function `GcodeSuite::M18_M84()':
M17_M18_M84.cpp:(.text._ZN10GcodeSuite7M18_M84Ev+0x118): undefined reference to `FastIOPortMap'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/gcode/control/M997.cpp.o: in function `GcodeSuite::M997()':
M997.cpp:(.text._ZN10GcodeSuite4M997Ev+0x54): undefined reference to `flashFirmware(short)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/module/configuration_store.cpp.o: in function `MarlinSettings::save()':
configuration_store.cpp:(.text._ZN14MarlinSettings4saveEv+0xe): undefined reference to `PersistentStore::access_start()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: configuration_store.cpp:(.text._ZN14MarlinSettings4saveEv+0x40): undefined reference to `PersistentStore::write_data(int&, unsigned char const*, unsigned int, unsigned short*)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: configuration_store.cpp:(.text._ZN14MarlinSettings4saveEv+0x50): undefined reference to `PersistentStore::write_data(int&, unsigned char const*, unsigned int, unsigned short*)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: configuration_store.cpp:(.text._ZN14MarlinSettings4saveEv+0x6a): undefined reference to `PersistentStore::write_data(int&, unsigned char const*, unsigned int, unsigned short*)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: configuration_store.cpp:(.text._ZN14MarlinSettings4saveEv+0x78): undefined reference to `PersistentStore::write_data(int&, unsigned char const*, unsigned int, unsigned short*)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: configuration_store.cpp:(.text._ZN14MarlinSettings4saveEv+0x86): undefined reference to `PersistentStore::write_data(int&, unsigned char const*, unsigned int, unsigned short*)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/module/configuration_store.cpp.o:configuration_store.cpp:(.text._ZN14MarlinSettings4saveEv+0x98): more undefined references to `PersistentStore::write_data(int&, unsigned char const*, unsigned int, unsigned short*)' follow
configuration_store.cpp:(.text._ZN14MarlinSettings4saveEv+0x47e): undefined reference to `PersistentStore::access_finish()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/module/configuration_store.cpp.o: in function `MarlinSettings::_load()':
configuration_store.cpp:(.text._ZN14MarlinSettings5_loadEv+0xa): undefined reference to `PersistentStore::access_start()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: configuration_store.cpp:(.text._ZN14MarlinSettings5_loadEv+0x44): undefined reference to `PersistentStore::read_data(int&, unsigned char*, unsigned int, unsigned short*, bool)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: configuration_store.cpp:(.text._ZN14MarlinSettings5_loadEv+0x60): undefined reference to `PersistentStore::read_data(int&, unsigned char*, unsigned int, unsigned short*, bool)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: configuration_store.cpp:(.text._ZN14MarlinSettings5_loadEv+0x90): undefined reference to `PersistentStore::access_finish()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: configuration_store.cpp:(.text._ZN14MarlinSettings5_loadEv+0xc0): undefined reference to `PersistentStore::read_data(int&, unsigned char*, unsigned int, unsigned short*, bool)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: configuration_store.cpp:(.text._ZN14MarlinSettings5_loadEv+0x10c): undefined reference to `PersistentStore::read_data(int&, unsigned char*, unsigned int, unsigned short*, bool)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: configuration_store.cpp:(.text._ZN14MarlinSettings5_loadEv+0x12c): undefined reference to `PersistentStore::read_data(int&, unsigned char*, unsigned int, unsigned short*, bool)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: configuration_store.cpp:(.text._ZN14MarlinSettings5_loadEv+0x14c): undefined reference to `PersistentStore::read_data(int&, unsigned char*, unsigned int, unsigned short*, bool)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: configuration_store.cpp:(.text._ZN14MarlinSettings5_loadEv+0x16e): undefined reference to `PersistentStore::read_data(int&, unsigned char*, unsigned int, unsigned short*, bool)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/module/configuration_store.cpp.o:configuration_store.cpp:(.text._ZN14MarlinSettings5_loadEv+0x196): more undefined references to `PersistentStore::read_data(int&, unsigned char*, unsigned int, unsigned short*, bool)' follow
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/module/endstops.cpp.o: in function `Endstops::report_states()':
endstops.cpp:(.text._ZN8Endstops13report_statesEv+0x70): undefined reference to `FastIOPortMap'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/module/planner.cpp.o: in function `Planner::quick_stop()':
planner.cpp:(.text._ZN7Planner10quick_stopEv+0x4): undefined reference to `HAL_timer_interrupt_enabled(unsigned char)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: planner.cpp:(.text._ZN7Planner10quick_stopEv+0xe): undefined reference to `HAL_timer_disable_interrupt(unsigned char)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: planner.cpp:(.text._ZN7Planner10quick_stopEv+0x38): undefined reference to `HAL_timer_enable_interrupt(unsigned char)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/module/planner.cpp.o: in function `Planner::_populate_block(block_t*, bool, XYZEval<long> const&, XYZEval<float> const&, float, unsigned char, float const&)':
planner.cpp:(.text._ZN7Planner15_populate_blockEP7block_tbRK7XYZEvalIlERKS2_IfEfhRKf+0x2a0): undefined reference to `FastIOPortMap'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: planner.cpp:(.text._ZN7Planner15_populate_blockEP7block_tbRK7XYZEvalIlERKS2_IfEfhRKf+0x664): undefined reference to `FastIOPortMap'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: planner.cpp:(.text._ZN7Planner15_populate_blockEP7block_tbRK7XYZEvalIlERKS2_IfEfhRKf+0xa38): undefined reference to `FastIOPortMap'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/module/planner.cpp.o: in function `Planner::buffer_sync_block()':
planner.cpp:(.text._ZN7Planner17buffer_sync_blockEv+0x5e): undefined reference to `HAL_timer_enable_interrupt(unsigned char)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/module/planner.cpp.o: in function `Planner::buffer_segment(float const&, float const&, float const&, float const&, float const&, unsigned char, float const&)':
planner.cpp:(.text._ZN7Planner14buffer_segmentERKfS1_S1_S1_S1_hS1_+0x9c): undefined reference to `HAL_timer_enable_interrupt(unsigned char)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/module/stepper.cpp.o: in function `Stepper::suspend()':
stepper.cpp:(.text._ZN7Stepper7suspendEv[_ZN7Stepper7suspendEv]+0x4): undefined reference to `HAL_timer_interrupt_enabled(unsigned char)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: stepper.cpp:(.text._ZN7Stepper7suspendEv[_ZN7Stepper7suspendEv]+0xe): undefined reference to `HAL_timer_disable_interrupt(unsigned char)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/module/stepper.cpp.o: in function `Stepper::set_directions()':
stepper.cpp:(.text._ZN7Stepper14set_directionsEv+0x94): undefined reference to `FastIOPortMap'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/module/stepper.cpp.o: in function `Stepper::init()':
stepper.cpp:(.text._ZN7Stepper4initEv+0x230): undefined reference to `HAL_timer_start(unsigned char, unsigned long)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: stepper.cpp:(.text._ZN7Stepper4initEv+0x236): undefined reference to `HAL_timer_enable_interrupt(unsigned char)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: stepper.cpp:(.text._ZN7Stepper4initEv+0x24c): undefined reference to `FastIOPortMap'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/module/stepper.cpp.o: in function `Stepper::set_position(long const&, long const&,
long const&, long const&)':
stepper.cpp:(.text._ZN7Stepper12set_positionERKlS1_S1_S1_+0x28): undefined reference to `HAL_timer_enable_interrupt(unsigned char)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/module/temperature.cpp.o: in function `Temperature::checkExtruderAutoFans()':
temperature.cpp:(.text._ZN11Temperature21checkExtruderAutoFansEv+0x54): undefined reference to `FastIOPortMap'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/module/temperature.cpp.o: in function `Temperature::updateTemperaturesFromRawValues()':
temperature.cpp:(.text._ZN11Temperature31updateTemperaturesFromRawValuesEv+0x1c): undefined reference to `HAL_watchdog_refresh()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/module/temperature.cpp.o: in function `Temperature::init()':
temperature.cpp:(.text._ZN11Temperature4initEv+0x6e): undefined reference to `HAL_timer_start(unsigned char, unsigned long)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: temperature.cpp:(.text._ZN11Temperature4initEv+0x74): undefined reference to `HAL_timer_enable_interrupt(unsigned char)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: temperature.cpp:(.text._ZN11Temperature4initEv+0x138): undefined reference to `FastIOPortMap'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/module/temperature.cpp.o: in function `Temperature::disable_all_heaters()':
temperature.cpp:(.text._ZN11Temperature19disable_all_heatersEv+0x6c): undefined reference to `FastIOPortMap'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/sd/Sd2Card.cpp.o: in function `Sd2Card::chipDeselect()':
Sd2Card.cpp:(.text._ZN7Sd2Card12chipDeselectEv+0xc): undefined reference to `spiSend(unsigned char)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/sd/Sd2Card.cpp.o: in function `Sd2Card::chipSelect()':
Sd2Card.cpp:(.text._ZN7Sd2Card10chipSelectEv+0x6): undefined reference to `spiInit(unsigned char)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/sd/Sd2Card.cpp.o: in function `Sd2Card::readData(unsigned char*, unsigned short)':
Sd2Card.cpp:(.text._ZN7Sd2Card8readDataEPht+0x12): undefined reference to `spiRec()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: Sd2Card.cpp:(.text._ZN7Sd2Card8readDataEPht+0x36): undefined reference to `spiRead(unsigned char*, unsigned short)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: Sd2Card.cpp:(.text._ZN7Sd2Card8readDataEPht+0x3c): undefined reference to `spiRec()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: Sd2Card.cpp:(.text._ZN7Sd2Card8readDataEPht+0x40): undefined reference to `spiRec()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/sd/Sd2Card.cpp.o: in function `Sd2Card::waitNotBusy(unsigned long)':
Sd2Card.cpp:(.text._ZN7Sd2Card11waitNotBusyEm+0xa): undefined reference to `spiRec()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/sd/Sd2Card.cpp.o: in function `Sd2Card::cardCommand(unsigned char, unsigned long)':
Sd2Card.cpp:(.text._ZN7Sd2Card11cardCommandEhm+0x1a): undefined reference to `spiSend(unsigned char)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: Sd2Card.cpp:(.text._ZN7Sd2Card11cardCommandEhm+0x20): undefined reference to `spiSend(unsigned char)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: Sd2Card.cpp:(.text._ZN7Sd2Card11cardCommandEhm+0x28): undefined reference to `spiSend(unsigned char)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: Sd2Card.cpp:(.text._ZN7Sd2Card11cardCommandEhm+0x30): undefined reference to `spiSend(unsigned char)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: Sd2Card.cpp:(.text._ZN7Sd2Card11cardCommandEhm+0x36): undefined reference to `spiSend(unsigned char)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/sd/Sd2Card.cpp.o:Sd2Card.cpp:(.text._ZN7Sd2Card11cardCommandEhm+0x42): more undefined references to `spiSend(unsigned char)' follow
Sd2Card.cpp:(.text._ZN7Sd2Card11cardCommandEhm+0x4a): undefined reference to `spiRec()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: Sd2Card.cpp:(.text._ZN7Sd2Card11cardCommandEhm+0x50): undefined reference to `spiRec()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/sd/Sd2Card.cpp.o: in function `Sd2Card::init(unsigned char, short)':
Sd2Card.cpp:(.text._ZN7Sd2Card4initEhs+0x18): undefined reference to `HAL_watchdog_refresh()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: Sd2Card.cpp:(.text._ZN7Sd2Card4initEhs+0x2c): undefined reference to `spiBegin()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: Sd2Card.cpp:(.text._ZN7Sd2Card4initEhs+0x34): undefined reference to `spiInit(unsigned char)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: Sd2Card.cpp:(.text._ZN7Sd2Card4initEhs+0x40): undefined reference to `spiSend(unsigned char)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: Sd2Card.cpp:(.text._ZN7Sd2Card4initEhs+0x48): undefined reference to `HAL_watchdog_refresh()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: Sd2Card.cpp:(.text._ZN7Sd2Card4initEhs+0x72): undefined reference to `HAL_watchdog_refresh()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: Sd2Card.cpp:(.text._ZN7Sd2Card4initEhs+0x8a): undefined reference to `HAL_watchdog_refresh()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: Sd2Card.cpp:(.text._ZN7Sd2Card4initEhs+0xc0): undefined reference to `spiRec()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: Sd2Card.cpp:(.text._ZN7Sd2Card4initEhs+0xf8): undefined reference to `spiRec()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: Sd2Card.cpp:(.text._ZN7Sd2Card4initEhs+0x108): undefined reference to `spiRec()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: Sd2Card.cpp:(.text._ZN7Sd2Card4initEhs+0x10c): undefined reference to `spiRec()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: Sd2Card.cpp:(.text._ZN7Sd2Card4initEhs+0x110): undefined reference to `spiRec()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/sd/Sd2Card.cpp.o: in function `Sd2Card::writeData(unsigned char, unsigned char const*)':
Sd2Card.cpp:(.text._ZN7Sd2Card9writeDataEhPKh+0x8): undefined reference to `spiSendBlock(unsigned char, unsigned char const*)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: Sd2Card.cpp:(.text._ZN7Sd2Card9writeDataEhPKh+0xe): undefined reference to `spiSend(unsigned char)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: Sd2Card.cpp:(.text._ZN7Sd2Card9writeDataEhPKh+0x14): undefined reference to `spiSend(unsigned char)'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: Sd2Card.cpp:(.text._ZN7Sd2Card9writeDataEhPKh+0x18): undefined reference to `spiRec()'
c:/users/xmexj/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/malyanm200v2/src/src/sd/Sd2Card.cpp.o: in function `Sd2Card::writeBlock(unsigned long, unsigned char const*)':
Sd2Card.cpp:(.text._ZN7Sd2Card10writeBlockEmPKh+0x50): undefined reference to `spiRec()'
*** [.pio\build\malyanm200v2\firmware.elf] Error 1
Thank you
