I have, finally, published a PlatformIO library AVRmillis
which is intended for use on the atmelavr platform but without a framework. It published fine with the library.json
containing framework * and framework none etc, hence I’m up to version 1.0.2! (link to library PlatformIO Registry )
When I try and use the library, I get this error:
Library Manager: Installing normandunbar/AVRmillis @ ^1.0.2
Warning! Could not find the package with 'normandunbar/AVRmillis @ ^1.0.2' requirements for your system 'linux_i686'
My library.json
file is as follows:
"name": "AVRmillis",
"version": "1.0.2",
"description": "This is a library for PlatformIO which allows anyone not using the Arduino framework, to write code which has access to Arduino-a-like millis() and micros() functions. The Arduino framework already has those functions built in, so this library is not suitable for use with that framework. The library has been tested on Arduino Uno, Duemilanove and Nano boards using the Atmega328P microcontroller. The library creates a class named AVR_millis, and a global object named AVRmillis through which the functions are accessed. See the readme.md file for full details.",
"keywords": "millis, micros",
"repository":
"type": "git",
"url": "https://github.com/NormanDunbar/AVRmillis"
"authors":
"name": "Norman Dunbar",
"email": "norman@dunbar-it.co.uk",
"url": "http://www.dunbar-it.co.uk/contact-us/",
"maintainer": true
"license": "MIT",
"homepage": "https://github.com/NormanDunbar/AVRmillis",
"frameworks": "*",
"platforms": "atmelavr"
I have tried with "frameworks":"none"
as well, but the same occurred. What is the setting for frameworks when there’s no actual framework required.
This is my first library specifically for PlatformIO, and I’m rather flummoxed to say the least!
Cheers,
Norm.
